Cruiserdrew
On the way there
Any progress on the "other" axle now that it's March?
Nice PIG!!!
I know the budget is already on life support, but maybe some Slee arms? Temporary solution, plates plus caster bushings?
That's what I did plates+ caster bushings.
Im going with Slee arms next....
The rear DS noise could a lot of things.
Over time I did; U-joints, LCA bushings, rebuilt rear axle and still had that lil annoying sound, until I went DC on the DS..
Looking good Cam..!!
Nice PIG!!! Your truck looks OK too. How about more pics of the 55?
For the rear, can I just point the rear pinion at the t-case, or is it more involved than that?
If you run caster plates, and caster bushing your front control arms might have contact with the tie rod on the rear of the axle...
Slee arms. They are great. By the time you do the janky for awhile, you could have been 100% with Slee arms the whole time. I think because the 60 is lighter than an 80, especially with a much lighter motor, you have the equivalent of a 5-6 inch lift. Thus, you need caster correction that would only normally be needed with a big lift.
Listen to these guys. Just spend the money. You tight bastard.
