PabloCruise
Is that ITM new or regrind?
New. ITM ENGINE COMPONENTS 0564515. I just looked up the number at Rock Auto where I got it and they are now showing "out of stock" . I hope that's temporary. First the Melling and now ITM. Jeeeez!Is that ITM new or regrind?
I have a set of Starrett gauges as well--easy to loan if you need-been off to a couple of members who needed them--have them back now--so available---I can lend my Brown and Sharpe, stamped "USA" telescoping gauges if anyone needs them; USPS small box. Lifter bores, cylinder bores, etc. I also have a nice Starrett combination square. The rule and the head on the combination square are good enough on most combination squares for measuring planes if you place a feeler gauge under them - you might need to remove burrs from improper tool handling, but, they usually work for shadetree mechanic purposes.
An old trick that a I learned from a Navy machinist was using a cigarette paper to feel out .001-inch. If you place the paper in a space and you are pulling it and the paper rips it tells you quite a bit more than noticing slight resistance on a metal feeler gauge. We could find where a part was in a milling machine vise by mounting an exact size pin in the spindle of a milling machine, and moving the table until the drag of the paper was enough to tear it against the part in the vice. I could see using the paper in the bore of the block, in conjunction with a telescoping gauge, to get a better sense of the size and roundness of the lifter bores. When you simply set the telescoping gauges, you have to do a careful dance to not collapse them against the sides of the bore, having that paper in there would tell me how tight it is set without moving/wiggling the actual tool to find out. Then once your telescoping gauge is totally set tight, then carefully remove it from the bore. Check the size between the two convex plungers on the bench with your calipers, or micrometer (preferred for greater precision), accounting for the .001" of the cigarette paper. I can also lend out an up to 1" micrometer, or a 1"-2"micrometer.
ITM cam and lifters from Rock Auto. I would have preferred the Melling MC803 but I don't think it's available. I say that because places like Summit, Jegs, and Autozone say it ships from supplier. The Melling web page doesn't show it. And when I called and inquired, all Melling said was that the number is still in the system but there are none available. They couldn't tell if they were discontinued or if they will get more. So I just moved on. I've got all the parts. Tomorrow is flush day for oil and cooling system and then it'll start going back together.
It’s coming along but not as fast as I’d like. I took apart way more then I needed to and can’t bring myself to put anything back without fresh paint and some fresh bolts. Cam & lifters went in yesterday, and today I re-pulled the crank pulley after finding the oil slinger on the bench. Rocker assembly went on also just as it got dark, so valve adjust will be at sunrise. Then the dizzy, battery, radiator, linkage and more. I’ll take a pic of where it’s at so far in the morning.Is it all back together?
I just looked and Rock Auto shows the ITM cam back in stock. Don't know about the Melling MC803. You could always call Melling support and see if anything has changed since I talked to them.Jinkees.
I looked up Toyota p/n 13511-60060 (3FE cam) and see lots of NLA messages.
I may be on a really short timeline when I get the 40 into the shop, so I am contemplating finding a used cam and sending it off to Delta so all my ducks are in a row when we pull that first lifter...
...I re-pulled the crank pulley after finding the oil slinger on the bench...
Quality Engine Exchange on N. Lamar Blvd let me stand by the boring and honing machine with my .001 and .002 feeler gauges and I checked every cylinder as he went along for clearance. They have since closed down (hopefully not for anything I did). Didn't need to deck the block. I used my 3'x3' laboratory granite block and Big sanding sheets to get the head flat. Did the valves myself using my old Sioux valve and seat grinder after installing bronze valve guide liners. It's getting really hard to find a machine shop in this town that's not back-logged 6 months. Sorry, don't want to hijack this thread. DougHey Doug,
I'm in Austin also and I have a 2F that is needing a rebuild. I have all the parts, so wondering who did you use for machining the block (boring and decking)?
Thanks
Ernie
Steamer, did you do the modification on the side of the head to eliminate the potential oil leak where the oil galley has a pressed-in plug? Requires drilling out the aluminum plug, tapping threads in the hole and screwing in one or two set screws with sealant.I was waiting delivery of new bolts for the timing cover and had some bolts that were too long holding it and the gasket in place so I could continue getting the crank pulley on. I only use Never-Seize on gaskets so no problem on leaving it loose for a few days. So, after oil priming was done, the 1/2 quart of Lucas laying on the concrete didn’t upset me too much since it confirmed the oil nozzle for the timing gears was functioning. For those who don’t know better, I planned it that way. Not a big deal as my oil dry disbursement drill is always well rehearsed.
Appreciate the reminder but I did the galley plug a few years back with the head in place method & used a 1/16” NPT tapered pipe plug & tap. Replaced the plug this time around.Steamer, did you do the modification on the side of the head to eliminate the potential oil leak where the oil galley has a pressed-in plug? Requires drilling out the aluminum plug, tapping threads in the hole and screwing in one or two set screws with sealant
Not knowing the answer got me looking around and just now found "THIS".Rings need friction to seat properly, and zddp apparently can impede that. What oil does one use when breaking in a cam and seating rings in a complete rebuild? And ring seating involves multiple rpm cycles after warm up (i.e drive it) but cam break-in process is at a moderately high ~fixed rpm (neither involve extended idle at temp). Just curious as I only need to seat new rings in honed cylinders.
