Bumper basket (1 Viewer)
Milano - Italy
I live in north Italy , and after using the HZJ 78 , for a good 10 years in the north Africa region , I find myself that this beautiful region is no longer adeguate for this rig .
So the decision ha been taken since a few years to ship the 78 , down in the south part of Africa , and precisely in Namibia .
The truck is fine and ready , but space is never enough .....not even on a troopie .
At present the front bumper is as in the above photos .
But I wonder if I can use this space in a smarter way ...
this is how far I got in the new basket .
the final work will be in aluminium 3 mm .locked in place via some bolts .
What do you think ?
That looks like a great idea, the perfect place to store some recovery equipment.
Cheers
Clint
My thoughts exactly! Very curious to see how it turns out.
here are some up dates
had to do a new mock up , plastic is too flexible no good .
started cutting some 3 mm thick aluminium , rather easy to work with , but the quality I have chosen is very rigid .
not good for bending ,
small update ,
this is the first of the two , semi finished .
it takes a awful amount of time working on the details .
still not finished but tomorrow I aim to finish this one and close the N.2 .
then I need to powder coat them , water seal them , and mount them .
all with in next week .
we'll see..........
small update .
both boxes are done , and welded .
need to make some small details before sending all to sanding and painting .
here is some pic of the testing
Nice work! I was wondering how you were going to seal it from water... but given your location that might be non-issue.
Water is always an issue.
The small edge that you see around the aperture is made to host a rubber seal.
I have opted for a 2 x 10 mm seal .
Hope that it will be enough.corners and small cracks will be filled with silicon ,prior to install the seal .
The lid will be hold in place with pressure through 2 lockers .
Hope me well with the water tight seal ....
But some thing will always penetrate , so a tap on the bottom will be good to drain the eventual water leakage.
hi guys , sorry for the very later update , but big projects are at last moving .
so the baskets have been , finished , sanded , seals ,power coated ,and fit with rubber seals all around .
tested , WATER tight :).
I don't have many photos , as the car is already sailing !
very glad the say that these small baskets can hold a ton of small and medium size objects that are always in the way in the cargo area .
