Build Building my GX470 for adventure and fun
@DNGRZN could you please give some more detail on the wiring in your truck :lol:
Lol I'm kidding of course:D ... God bless you my good man ... you are thorough and thank you for taking the time to document it the way you did ... Im sure it took you much longer to do that than it did for me to read and comprehend it...
:pompous:
I'm putting an Incognito together this week with the new revisions and doing a test fit ... if all goes well it will be for sale .... and many more behind it
:worms:
LOL, Sorry it was long winded, lol. I remember when I was first learning about building these I wished more people would have made clear how to's, and told myself I'd do my best to make it easy for others. :) You are totally welcome. I love what you are doing with the incognito and look forward to seeing such a slick deal come to market. I'm hoping you are having some fun with it! :beer: Thanks for the kudos, and cheers!
Well it certainly seems like you know what your doing ...
I'm no electrician ... I know electrical work about as well as my kids know about wearing shoes ... they know they go on the feet but not sure which ones and need someone else to tie the laces :hmm:
I'm having with the new venture just wish I had more time to dedicate to it ...
Thanks much. I'm studying to be a nurse now, but I am an MECP certified Master Installer, and worked to "pimp rides" in every way imaginable for 12 years before going back to school. Electrical and Fab are now my uber hobby since no one pays me to do that stuff anymore. I can't help your kids figure out shoes, but if you ever want to know anything about electricity, feel free to ask. Some of the failures I see offroad are electrical related, and I like to make sure everyone has solid electrical, so I get pretty OCD about it. :bounce:
Well, I know some folks are planning radion installs soon, so I don't have time to write it all up at the moment, but I'll at least post pictures to help with ideas and edit later.
Cheers fellow Hams.
THe radio programmed on the bench
The basic parts and tools
The face to main unit cable face side note the color orientation
The main unit side, note the space and color orientation of the wires. Also note that this is a standard cat5 cable end.
I really wanted the radio face above the mirror, so I carefully took apart the sunglass holder and then took a simple piece of stainless 3/16 steel and bent it at an angle I liked, then pop riveted it to the top of the housing. I put some good velcro on there and drilled a little hole in the drivers side of the housing so I could run the cable through. I used some 4 conductor (22gauge?) shielded security wire from Home depot and left a few feet hanging out for later. I then was exceptionally careful to run the cable down the drivers A-pillar BEHIND the airbag with the factory wire loom then down to the floor panel.
Then I took a standard 4 pin phone cord (I'll look up the connector type and post it with a parts list later) and crimped it on matching it to the factory wire pattern in the above photos.
You will notice that I pretty much gutted the entire center console, I did this because I wanted the MIC to go in here, and planned to add another radio later, and so ran 2 mic cables. For the wiring I bought some basic cat5e or cat6 cables (I forget, but the shielded ones) and cut the ends off of one side and ran them from the center console area to the drivers sill area, leaving enough room to manipulate them later. I came out with the cables about where the blue plug is in the middle.
I used a small dremel tool and cut some plug jacks into the back side of the center console pocket (this area is a tight fit, so measure carefully to avoid nicking anything else.) I plugged the CAT cables in here and reassembled the center console.
This lets me plug in the mic cords for most modern radios and remove them at will for theft deterrence or replacement. Note that I used a megnetic rf isolator clipped around the cable at both ends to shed rf interference on the line. (Cheap and easy to find online)
Then I gutted the back for a few reasons. I was running the fuse box and power cables in my batter writeup, but also because I needed to access the roof for mounting my antenna, and I just wanted to have lots of room to work to get things right (like the much larger power inverter that lives near the subwoofer now. I also wanted to make sure that there were no sensitive vehicle electronics close enough to get fried or tripped up by a radio transmitting close by. I wanted my radio higher up as well in case I ever take a swim and forget to roll up the windows :)
I chose this pocket for several reasons, mainly ease of removal in case of issues, replacement, programming, cooling by opening the cubby if I TX a lot, and the easy space for adding another radio later. While I had this all apart, I also ran some 4 conductor wire (same stuff I used for the control unit, but soldered some speaker connectors to it so I could mount some speakers in the front of the cab so I can hear the audio.
Now, antenna placement is huge on a HAM rig, and so I deliberated a lot, and decided that I'll likely make a cutout in my roof rack for this one. The best place would have been the center of the roof, but I just couldn't bear to do it, so I figured the least loss with the best ground plane would be about 6 inches forward from where this image shows the antenna. I did a Larson NMO mount, and drilled through my roof. Now, I am not going to get into a how to for that part except on a case by case basis, simply because if you mess this up, there is no coming back from it. If you want an antenna like this and have not done them before, I'd recommend taking it to a HAM radio shop and paying to have them drop the antenna lead for you. It just isn't worth the risk to "try it out".
Now, I got a little excited and forgot to take lots of pictures, but I cut a small slot in the pop out tray that goes in the side, and I removed the sound deadening from the bottom of it, match marked my holes with a spring punch, and drilled them. I bought some longer m8 screws with wide washers and used the factory bracket to screw through the bottom into the radio, and then added 2 more screws that go through the plastic into the metal bracket in the space away from the radio body to provide side to side support. I ran all my cables into the cubby, and mounted it in place, and then screwed everything in. Not pictured I also put those same clip on magnetic isolators over the speaker, mic, and power lines. Here in the back I also had to crimp on an end for the mic wire that matches the wide end of the factory extension cable. It was kind of a pain to line up, but once it did, it was perfect. Note, that I am not sure if this helped or not, but some people report noise on the mic line when they make their own cables, I do not have any, and I think it is because I used the shielding wire (drain wire) that runs in the shielded CAT cable and I connected only one side of it to ground to help reject RF interference. Whether that did it or not, no idea, but I have a clean mic line.
That is the gist of it. I will try to track down a parts and tools list. I bought and returned several tools because they sucked, so hopefully what I used it still available.
The last thing I did was use some non-powered cell phone hands free speakers I had in the shed (cb radio ones work too, match the rated impedence on the radio though) and mounted them between the factory radio amplifier, and the transmission hump under the drivers seat. This creates a horn loading effect in the footwell that brings the audio up pretty darn clear with no speakers cluttering up your dash space. I connected those to the speaker cables I ran earlier and then fired it up and made my first contact. IT was pretty cool to have it work out of the gate.
I'm no elmer, but I know a little bit about setting up a ham rig in a modern car if anyone is new to the idea and wants to ask a question here an there. I'll know, or I wont, but I know I wont lie to ya. Good luck Y'all.
'73
Awesome write up!
Really clean install
I really need to get the non dvd center consol to replace mine with a useless dvd player in it, there is so much more needed room.
Sent from my SAMSUNG-SM-G925A
We can arrange that, lol. Road trip!
Sent from my Nexus 6
Where do you live. I might be serious lol
Sent from my iPhone
Portland may work. Have a few plans on GXs they could bring me west a few times
Sent from my iPhone
Sent from my iPhone
Lol, dedicated you must be. Strong with the gx force you are.
If you'll be out here, we plan something for sure. I'll PM you later today with some details since school has planned my life for me into the future a little ways.
Hey I might want to pick your brain as I just quickly tossed in my uhf/vhf yesterday and want some other more serious mounting location ideas. I use my sunglasses holder too much so that won't work, but I'm sure we can figure something out. And your wiring... I need a guru incan learn from on that account.
Sent from my XT1585
Sent from my XT1585
Lol, for sure. I thought I couldn't live without the sunglass holder either, but I tried just using the hard case and throwing them in the console and that worked out well for a month so I just went for it. It's possible to maybe do a mount on the rearview or to the glass using a go pro mount. The mount options depend on whether you have the in dash nav or not. I bought one without that simply because after doing installs for a long time I knew how big a pain that was to remove, so I skipped the headache. What questions might you have? I'm happy to try to answer them. :)
Just saw you're in Vancouver, and happy to connect sometime too if that's helpful. My schedule is razor tight, but I can work fun in.
All of your upgrades are VERY impressive! When time permits, I'd really like to learn more about your underhood lighting. I'd really like to have something under there.
Thanks.
The underhood is pretty simple. Basic premise is two kc hilites cyclone lights. I wired them in parallel to some two strand direct exposure sprinkler wire (home depot calls it buriable cable) in 22 gauge I believe. I ran the lights off a 9volt battery to see their spread pattern and mounted them where they seemed best to my eyes with a washer and a single screw through the middle. I used split loom 1/4" over the wires (soldered, electrical taped, and then shrink wrapped, before going into loom) and tucked the wire loom under the underhood fiber shield. I ran it down the drivers side to the gas strut and left slack for the wire to fold when the hood closes and then mounted it with a zip tie to a bracket.
I then ran that to my fuse box in the writeup, and connected ground to the ground buss bar. I took a strand of wire about 40 inches long and folded it over, taped it every 3 inches, and placed that in wire loom and Then connecting one end to a low current (3 amp) fuse on the blue sea block and the other to the positive tail heading up to the hood lights they come on.
Now I found where I wanted my switch so I could find it in the dark, so I put it in the plastic panel to the right of one of my dzus clips. Easy to feel. I drilled a 3/4" hole and put a 3/4" spst switch in the hole. I cut the "loop" at the end of my folded positive wire and connected the two ends to the switch (I solder everything and shrink wrap). Now I can turn lights on and off.
Now an optional part. I wanted to be able to remove the panel and switch during major underhood work without cutting anything. So I found a place near the fuse block and cut through the folded red wires and loom. Here I installed a powerworx quick disconnect (same stuff as listed in my wiring write-ups) so i could pull it apart quickly. No real need to tho.
I'll go take some pics one of these days and upload them. Hopefully that helps. Thanks for the kudos BTW. :-)
