Christo,
Please explain more as I am in this scenario (E-locked, 37's, & wheel hard). Is it a strength/durability issue?
Thanks,
Derrick
Derrick, want to trade rear axles?
-Harley
Christo,
Thanks,
Derrick
One disclaimer-I have seen Polys walk out of the axles they were in twice after shearing all the studs. Might have been a fluke, and the individual involved is not known for tightening things up and checking religiously. I have a suspicion that the poly cone washer taper may be slightly off, but I have nothing more than looking at several to back that up.
Cough, cough....I tighten things yo!
Or are we talking about Alvaro?![]()
Dude-You are supposed to be at Hole in the Rock. And yeah, Alvaro does not believe in torque.![]()
Your cheapest and best option staying in the stock plus category, is to take Christo's advice. Get a regular non-locker rear axle and use an ARB. Keep the front e-locker, but when you gear it, have a solid spacer installed in place of the pinion crush sleeve. (Just Differentials sells a nice piece for this and it isn't expensive).
Then upgrade the shafts/birfs - Longfields up front, and Polys or stock in the rear.
Install the ARP hub studs front and rear, and do the dowel pin mod as described. Keep everything tight and check before every wheeling day.
That is about as strong as a sort of stock 80 axle is ever going to be.
I'll bet you never break anything, but you are going to spend a bunch of money.
Now the link to Dusty's truck is worth talking about. It's superbuilt with a D60 up front and a D70 in the rear, and I believe he broke the rear D70 if I remember. It's awesome as a wheeling truck, but it's also a massive project.
I think you are on the right track trying to stay stockish with improvements but not wholesale replacements. Once you do that, I'd be looking at a different platform.
Good luck.
Wait am I to belief from what I am reading from this thread that my stock axles in my 96 are weak? Should I not go wheeling. What about all those wild wheeling pics? Do all those guys have different axles? I have e lockers. Or are we talking about extreme rock crawling. I'm confused.
Nope, you have awesome axles. Check them to make sure errythang is tight, and go beat them like it stoled your bike! They'll take the abuse. Unless your jumping and/or bouncing through a rock garden, and keeping your body panels in good shape... the axles will be OK.
That's always been my take, if you plan to keep the body good, then the stock axles will hold up plenty fine. It's when you get to a point where you don't care about sheet metal is about the same time your axles are not strong enough.
Land Speeder said:That's always been my take, if you plan to keep the body good, then the stock axles will hold up plenty fine.
Stock axles, or stock e-locked axles?
Yes, it's baited, but since the conversation has began.....
Land Speeder said:e-locked will be fine with 35" or smaller......stay at 35" and them e-locked axles should be fine.
There's the first problem.
Going to see what results from Rick's spline grind thread and work on the front, for now.
The general consensus, regardless of elocked rear, PPs or OEs rear, is still Longs for the front, right?
Yeah but their coopers. Could have bought them a week ago and they look like that.![]()
X2. Got my e-locked rig in 2004, put the 37" tires on it in 2006, so almost 100K on the 37"s. It sees ~40 trail days a year, some easy some "station wagon rock crawling".Has been to Utah/Moab a bunch of times, easily a couple of months of trail days, including 8x on Golden Spike.
Axle repair/maintenance has included brake pads (original rotors, calipers), wheel bearing repacks (original bearings), gear lube changes, moly pumped into the knuckles. About 6 yrs ago, had the right side knuckle nuts come loose, didn't catch it in time, broke a stud, so it came apart, studs replaced, new seals. The driver side is factory, has never been apart, but is showing signs of birf soup starting, so will be coming apart, getting new seals soon,,, ish.
In my experience, it is all about how you treat/maintain it. If you momentum drive, wheel in slop, hop tires under load, don't care, will break stuff, early and often. If you treat/drive it like a 3ton station wagon, they are very durable. For a station wagon they are amazingly capable, can make big obstacles look easy. In my experience, controlling wheel spin is key, in most cases, easily done by left foot braking.
Got new tires in Jan, this pic was shot in New Years day, yep, she gets wheeled a bit.![]()
