Builds Building Bubbles the Turbo Super Tourer (1 Viewer)
Putting any weight up high is going to increase your center of gravity. This setup that ai have is way lighter than the old setup I had on top of the Cummins 80. This one is about 120lbs lighter. I do have a HD rear swap bar which I would highly recommend and really nice suspension, which makes the handling both on an off-road much nicer. That said, on the last trip I rallied this 8100lbs cruiser hard with the tent on top and a double swag and firewood on top of tent load bars. It’s a good setup for what I like to do.
Right on! Thanks man, your 80 is functional and looks badass.
Today I swapped out the lens on 2 of the 3 Baja Designs LP9 lights in the front bumper. I have been using the ‘Driving’ lens on all of them, but wanted to see what it would be like with 2 of them in a spot beam pattern.
I went for a drive around the neighborhood tonight, and am really pleased with how much throw I now have.
This video shows, low beam headlights, then high beam headlights, then low beam, then LP9’s on.
Putting any weight up high is going to increase your center of gravity. This setup that I have is way lighter than the old setup I had on top of the Cummins 80. This one is about 120lbs lighter. I do have a HD rear sway bar which I would highly recommend and really nice suspension, which makes the handling both on an off-road much nicer. That said, on the last trip I rallied this 8100lbs cruiser hard with the tent on top and a double swag and firewood on top of tent load bars. It’s a good setup for what I like to do.
Agreed the hd away bar made a HUGE difference on my 80. I went with the 100 series extended links but the Rubicon ate those alive. Cruiser outfitters suggested slee extended brackets and stock links.
Does the Koala have any thoughts on this?
I'm digging your build thread and am considering starting one for pebbles, I would just need to go back and document all I have done over the last 2 years.
Thanks for sharing
Nice build. Definitely stealing some ideas to put on my build. I’m also interested in those sway bars. My truck probably weighs 7500lbs or more now with the duramax swap. The body roll is pretty damn impressive. Maybe the hd sway bars is what I need!
Thanks for sharing
I have been running the HD rear sway bar and the extended links that @LandCruiserPhil sells. His links remove the stock mount all together. That combo has been working really well for me, but I do plan to swap out the stock front sway bar for a HD sway nay in the not too distant future.
I need to go read through your duramax thread. I heard you worked up a big 5” snorkel…I need to figure out a similar setup for my Cummins.
I’ll save you the trouble of digging through my thread haha…unless you want to read over the build.
I think this might be the largest snorkel on a 80? I don’t know if any of the aus guys sell anything this size. I wish it was 100% seamless, I fit everything best I could.
View attachment 2843767View attachment 2843768View attachment 2843769
You did a nice job putting that together. Did you already have a safari snorkel the you were trying to reuse the existing cut and mounting holes? Or did you start from scratch for this build?
Ahh, Dave mentioned those I'll grab a set, thanks.
I'm digging your build thread and am inspired to start my own.
I'll read up on your Tcase before I ask what told you it was time ;)
Yeah originally it had a knock off ebay snorkel. Which I thought looked great they just flow really bad. It would flow enough for the previous ls swap, but I knew the dmax would need a lot more air. I had a 4” I built before this one, and it seemed to be ok but still not enough.
I can sell you my old 4” snorkel if you want haha. It would be cheap…like $100, but shipping would be expensive.
That’s really nice work. I’m in same boat as Morgan. Need more air and already have a Safari snorkel hole. I will be looking at 5” now looking at yours rather than 4”
Not haveing a big fat snorkel on is the reason I had to pull my 6BT out for another rebuild. All the Cummins guys really need a good fat dorkle solution.
How is this related to the rebuild? Causing you to run rich because of the intake restriction? Sorry if this is obvious to everybody else...
I was running a cummins panel filter in a custom housing, not running through a snorkel. Running in a group offroad in the UT desert for a few days, oftem at the back of the pack resulted in my filter clogging with dust and the vacuum created by the cummins pretzeld the filter allowing dirt to suck through the motor. Dusting the cylinders wiped the rings, in particular on cylinders 2,3 and 4. #3 being hte worst with 30% leakage during a leak down test. I plan to put a big 5" snorkel attached to an industrial earth moving equipment filter when it goes back together....painfull lesson.
Gotcha....that blows...or sucks...depends on how literal we're being haha. So, what I'm gathering is there's no good way to mesh a Safari unit with the needs of a 6bt. Unfortunate, since I have the former and want the latter. Guess I'll add custom snorkel to the swap parts list...
Yeah that’s right, the 6BT needs much more air than you can stuff through a safari snorkel.
5" dorkels (I'm keeping that one!) do exist here, but are not common. Not many here run anything bigger than an LS V8 or a Ford Barra i6 as transplants, Cummins etc aren't accessible here so we don't really need anything more than 4".
But have at it you lot!
If I remember correctly, one of the TLC V8 conversions kept the safari but made a custom air box that had an additional inlet. This satisfied the need for extra air during highway/fast driving but allowed the driver to close the box off on an as-needed basis. I think that's an interesting solution but it introduces more complexity to the intake and it would be easy to forget to close the box before you, I don't know, drove through some water or whatever... Taking the time to size the snorkel correctly is probably well worth the effort in the long run.
Thats what I have at the moment. My Donaldson air filter housing has a cutout that can be covered if needed.
