Brown radiator
@2001LC - To aid in your data collection, I'll add that I recently bought a one owner 99 with 245k miles. Currently at 250k. Service records indicate two TB/WP changes over the years. No indication of a radiator change. When I bought the vehicle it had red coolant (assuming Toyota). I changed the T's and think it was not needed as the old ones were stout and black. The plastic radiator tank is also black and I am assuming the original Toyota part because I have seen no record of it being changed and has a Toyota part number on it.
Thanks.. Very interest, too bad you don't have more history from PO.. Was it always in the Kansas area?
I'm still digging into records and texting back and forth with PO of my (new) 01 LX. But this guy really is/was clueless on maintenance (Jeffy Lub). I've called each Lexus Dealer that showed on vin #, but lots of gaps. I did think it currently has/had Toyota red, but have found there is another red on the market. Since it's red is not correct color match and done last at non dealer, I've surmised it's not.
It has always been a Kansas vehicle. Bought new 2 hours east of me and lived it's life 2 hours south of me. Unfortunately, I purchased the 100 from the widow of the original owner; she didn't know much about it's history so all I know is what Toyota has reported.
Hey guys. Wrapping up a TB job on 03 100 series with 220k (2nd TB) and went smoothly until I noticed the radiator top inlet a little dark and flaky (like a bad heater hose tee).
So the question is: should I replace the radiator?? The inlet flexes and I bet would crack if I fooled with it too much...
I love this truck, but age needs attention :)
I've one worst with 350K miles on it. I have schedule it on my watch list for replacment along with hoses. But for now I'll just keep and eye on.
Yowza...! :eek:
That doesn't look at all good. I think at the least I would grind that 'hose stop' off and let radiator hose slide up farther on the good part of the inlet.
I'm still working on issues (sounds), so this radiator takes back set until i'm sure I've got a rig with "good bones". Biside I'll keep within 15 or 20 miles of home and I'm very keen on sounds and smells. I just showed pictures, so OP didn't freak at his minor discoloration.
Engines get in trouble and overheat warping heads, not from driving a few minutes without coolant system working. But from ignoring the signs and driving until dead.
Oh that sweet smell of coolant, gotta love it!;)
Thanks for looking out for me!
Problem is once it blows apart youve got seconds to pull over and stop engine- if youre lucky enough to notice it happen. As you are aware, once the red light comes on its just gotten expensive.
@danimal24 , since your cooling system is empty already, if your budget allows replace with a new Denso $170
I would have replaced it, but had to wrap it up to have the beast ready for Hurricane Flo!!! 2001LC gave me confidence!
I am not so sure on that. I have seen picture of the 2001 LC that he sold with brown radiator.
I still see that 01LX with brown radiator top, I believe you're referring to.
More than two years and 40K miles more (~250K) since this picture, without change or issues. That said, I have recommended it be watched closely, be alert to the sweet smell of coolant and schedule it for replace on or before next flush.
The above brown radiator actually looks a little better today, then when that picture was taken. The coolants in it, has been regular flushed, topped and plastic top treated with Lexol plastic cleaner conditioner. How long will it last, who knows.
I've come to the opinion that the brown we see in coolant plastic parts is sign plasticizer is drying out. Plastic then start becoming brittle.
Have you ever notice it's the high points where air pocket form in coolant system, is where plastic turns brown, but lower areas seem to stay black. This just one of the reason I press upon everyone to check coolant level by looking under the radiator cap. What I like to see, is coolant to very top of radiator to assure we've no air pockets.
Some can't just be placed on watch or scheduled (budgeted), they need replacement ASAP.
Here the bottom of same radiator.
1788284
I don't think I have seen this one before. If this is from a LX, then definite not this one.
This is what I remember from Bye Bye to The King: Windshield rust repair ++. With the way you replaced other parts, I was surprised the radiator was not replaced.
045-jpg.1557465
045-jpg.1557465
You have seen picture of that LX before here in mud, and more than once @medtro.
The one you've picture and link The King.
When I got that 01LC around 2003, coolant was ~1/2" low and radiator looked a little darker as I recall at 60K miles. It, The King, after ~13 years ~100K miles more, was still fine. That radiator isn't a radiator I even consider scheduling for replacement. I started babying that coolant system around 90K miles with Toyota red and flushing every 2 to 3 years. It's where I cut my teeth on Land Cruisers, learning the value of flushing and burping.
If every radiator in a Toyota that turned brown blew, we'd have a worldwide shortage of radiators.
It's more important to replace thermostat & cap, as those can blow radiator if stuck closed.
So yes, brown plastic is and indicator, but don't freak out just for that. Tees are a little different in that torque of engine could pull apart and they tend to leak with age. Leaks (any) need addressing! Tees are something I just do as a PM these days, not so two years ago (learning).
Here's the Tee's from The King after ~16 years and 165K miles. They are hard and still usable.
So why am I seeing Heater Tees in 06 and 07 w/~60K miles that breaking apart. Is it a difference in plastic?, difference in coolant? (LL 2yr vs SSL 10 yrs/5 yr), years coolant in system before flushing or a combination of?
I think leading cause is length of time coolant remains in system. That fresh coolant has all it properties (additives) intact like the plasticizer, which age depletes.
Secondary is heat speeding up loss of plasticizer.
Thirdly, that a system low of coolant will dry plastic parts in air pockets after every cool down, leaching out plasticizer faster.
2006 at 60K miles. ~60k to 200K miles in 06-07 all have been falling apart. Higher mileage tend to be lighter (brown) in color. Note: only ~1 in 4 of these had coolant leaks and ran system low.
So here's 19yrs and 350K miles from a system that was 2 " low on first inspection. Lexus reported coolant low when they replaced the front water bypass pipe hoses (oil cooler) about 70K miles ~3yrs earlier, with aftermarket hoses and clamps. I had to R&R all those hoses & clamps with OEM as they where leaky. This is same radiator upper inlet gooseneck picture earlier w/350K, that I've "schedule" for replacement (along with upper & lower hoses, and transmission cooler hoses and water bypass joint front). In fact I drove around yesterday 93 F OAT, terrible stop and go traffic for 6 hours. I've zero leaks now, so rad can wait!
Here's the top of the 350K 19 yrs old, not all that bad except the strange marks/corrosion spots.
It's the goose neck gouge, pits and chips that put this on replacement schedule, more so than color.
I've a neighbor with a 98 w/250K that never knew he needed to maintain his rig, just drove. It had factory timing belt, water pump until I convinced him to replace recently. He still has factory Tee's and radiator. Tees are covered with pink gunk and radiator is browner than any I've seen. I've press on him hard to change out the tee's.
Here's what I see happening to his tees. First I could grab with my hand and pull apart if I tried. With age engine & trany mounts they will be soft. A hard stomp on the gas pedal and engine may move just enough to pull tees apart. Also coolant is leaky from them which all leaks need addressing.
His radiator is not leaking, so neither I nor Slee (Just in Slee for a bunch of stuff) has recommended more than be aware of and keep eye on radiator & coolant level.
Yes @medtro you've seen me replace a lot of parts, I'm now averaging 300 parts (7 qts of oil = 7 parts). Many because they are out of service (don't meet spec of FSM) other because of incremental benefit it gives, and some depend on objective of project.
But I've only replace two radiators, one was leaking at seam in front, which is the most reported failure/leak point. The other is in post #37 above as it was cracked gooseneck, additional it had exhaust gas blowing in it. I believe that one was run low on coolant for 20K miles and had air flow blockage. I think (but will never know) the head gasket blew before taking out the Heater Tee. That radiator showed zero signs of leaks.
As much as I may like to replace ever parts on a rig, it's not practical nor necessary. A rigs intended use is also considered when deciding what to R&R. Is it a DD, going deep into backcountry or a third word country far away from any assistances.
Bottom line, color is indicator of condition but not what I base final call for replacement on.
Keep coolant topped and fresh and be alert to smells and sounds regardless of color. ;)
I meant I don't think I have seen the brown radiator picture of that LX before. I know I have seen your LX pictures.
Brown radiator usually couples with tiny cracks on top plastic tank in a few cruisers that I have seen. I replaced it when that happened. It is not worth the risk of ruining a good engine for less than $180 in my opinion. That is less than 2.5 tanks of gas for many owners. If a broken T can ruin an engine, so can a broken radiator.
Alert to smells and sounds is good but not all driver can be trained to do that.
