My truck started making a strange click backing out of the driveway. Checked all the usual suspects ( shock mounts,u joints) not the problem. Turns out my redneck skid/crossmember mounts had a loose bolt and was allowing a small amount of movement when the frame twisted slightly when i backed out. So i tightened them and one broke and it happened to be one with a captive nut in the frame. I dont have a tap set so i took it to a friend who is the only mechanic i will let work on my baby. We welded a nut to the small portion still sticking out of the frame that ended up breaking off flush with the frame. Im not really sure where the drilling out went wrong but he ended up walking the bit out the side of the nut so what im left with is a C shaped captive nut that wont allow the bolt to be tightened. My first question is am i risking the whole skid shearing the 7 other bolts by driving and light wheeling with one bolt missing while i figure out how to fix this? My second question is how do i fix this? Do i A: use a hole saw to drill out a small access hole adjacent to the captive nut through the side of the frame to remove then reweld a new nut then weld the access hole shut.
Or B: holesaw from the bottom removing the captive nut along with a washer size frame bit that the nut is welded to and re weld a new nut/ washer where it was removed from?
Or C: use a very long drill bit to go in through the exsisting bolt hole out the top of the frame and usea very long bolt to go through the frame and put a bolt and washer on top?
Any suggestions are greatly appreciated.
