Uncle Touchy?
Yup, that uncle....with a year's worth of "Soldier of Fortune" issues on the coffee table (milk crate)
But we digress...back to this beautiful 4E8 60!
Uncle Touchy?
That is a good looking wagon to start with. A little fine tuning of the mechanical bits and it'll be sweet.
In this pic, at least 2 of the vac hoses at the top of the carb are misrouted. Get the emissions FSM and go through each hose and get them all routed correctly.
Ok, so I went through the vacuum plumbing again and I'm now up to maybe 90-95% on it being correct. And, I found another issue...The VCV for the distributor vent had a bad diaphragm and was leaking vacuum:
I removed and replaced the whole works with a direct line from the distributor to the air filter. Are there any downsides to doing it this way?
Also, per the instructions in the emissions manual. I've confirmed operation of the EVAP canister, EGR, and I'm pretty sure the HAC is behaving like it should (or at least its not doing any harm).
I recently replaced my failed VCV on my 60 and ran through the same mental exercise. The result? After several moments of pain, I decided that it was more difficult to get my head around than I initially thought, so I left it at that.
I was trying to figure out how the dern thing worked. This is how far I got. I stole this picture below from Joe_E...cheers, Joe.
When vac is pulled through port S, air is allowed to pass into the distributor on the cap side of the vac advance diaphragms. Presumably, this adds positive pressure to the distributor side of those vac advance diaphragms at the same time as there is a negative pressure being applied to the other side of those diaphragms as a result of the vac line to the port on the first vac advance pot (that line goes to the carb, through the check valve and BVSV).
So, the question I was asking myself, and for which myself gave me no reply, was do you really need that positive pressure for the vac advance to work?
Does that help or just drag you down into the abyss with me....?
My understanding is that S and X are on opposite sides of a diaphragm that controls flow through Y and Z. So, if I apply a mighty vac to port S, it should hold vacuum (at least that's the result I got with the Evap vcv)
I could be wrong though....
Alright, I checked the routing of the vac lines off of the dizzy VCV on my rig.
Y - connects to air cleaner (draws in clean air!)
X and Z - loop together and connect into the dizzy cap (the other connection on the dizzy cap goes to the air filter on the passenger side firewall)
S - connects to the vac tubing on the front of the vehicle in front of the valve cover/on top of the thermostat housing
so, when vac is pulled onto S, the VCV opens and allows air from the air cleaner to pass through Z into the dizzy. I guess if there is too much air, it can circle around again through X and back into Z. Any excess build up of air under the dizzy cap must pass out through the the air filter in the cabin.
Then I guess I'm back to my original conundrum. Do you need to draw air into the dizzy cap in order for the vac advance diaphragms to work properly, or is ambient pressure (the way you have it set up now), sufficient.
Why would the engineer it this way, there must be a reason?
Sorry for the delay; I haven't had time at a computer and detailed responses are a pain on the phone. I haven't had much luck finding documentation on the vent system, but here's my best swag based on what I've been able to locate:
Actually, its the air cleaner that draws air from the distributor
Correct
When vacuum is pulled on S, the VCV opens and allows air to be drawn through the cabin filter, and then through the distributor, and then into the engine air filter. X serves as a vent to allow the diaphragm in the VCV to operate freely
This system has nothing to do with ignition advance. Its only for ventilation under the cap. I'm also curious if my current setup is going to be sufficient
My best guess is that this is so airflow through the vent system only occurs when the engine is running. Otherwise when the engine is shut off, the possibility exists for backflow, which could potentially introduce flammable vapors to underneath the distributor cap and maybe even unpleasant engine odors into the cabin. A checkvalve would have been a less complicated approach, but I'm guessing there's not enough of a draft to actuate one on a reliable basis.
Got my header installed over the weekend...
Here's the old one. Judging from the gasket, I had a leak or two
slipped in for a test fit. I had to do something about the EGR setup and the splash guard near the steering box needed to be removed. Other than that, it fit in there pretty good:
Sorry, no pics of the completed install (or the swearing/small fire while building exhaust). It runs a lot better though...
I picked up a new header set in a bulk part purchase recently but have been reluctant to install based on mixed reviews here on MUD. I would love to hear more of your thoughts on it after a few miles of driving... Sound vs. stock, ease of sealing and performance increase ( if any). I love the look and have an exhaust leak to remedy as well, so a little motivation to proceed would go a long way!
Thanks,
Eric
