That is the adjuster, and it is beat to ****.
Is this the adjuster???
Badass. You are probally already doing this but do only one wheel (take apart) at a time, then you always have the other side to compare & use for reference.
And your return springs are on incorrectly. The 2 long springs in the picture...one os supposed to be attached on the outside of the shoes & the other is supposed to be on the inside. You need a FSM or Haynes..both have good pictures.
John
In his defense, I don't think he was the one that did the previous brake job on the vehicle, so it was somebody else responsible for that one.
badass,
Great advice you're getting here. What I do to check and see if drum brake cylinders are bad is to lift up the side of the dustcap on the end of the cylinder, and if fluid leaks out, you need to do a rebuild... chances are the insides of the cylinders are getting rusty and the rubber seal is worn out (if it's leaking).
From what I can see, though... aside from the return springs being a little funky, the rest of the brakes look good.
Just wondering, i pulled up one of the rubber seals on one of the brake cylinders that i was planning on not replacing, and it did not leak fluid but it was wet. Should i replace?
Do you guys think rebuilding the calipers for the front discs is a good idea??
No. Get some that have been rebuilt professionally. My local Napa carries the Land Cruiser calipers in stock. They come loaded with pads and seem to work just fine.
Just curious, are you suggesting this because of your doubts about badass's skill in rebuilding calipers or do you think properly rebuilt calipers aren't reliable? I helped a friend rebuild the calipers on his 62, and it didn't seem that hard. Should he have just gotten new ones?
