Update:
For those of you who find this thread searching for possible solutions to your own brake problems, I have the following information:
The combination of the largest of the 4runner/T100 calipers (S13WB castring, 4X45mmm pistons) and the original master works, that was not the problem, it was me who got some lines crossed to the LSPV.
Btw. If you experience problems getting a firm pedal, be sure to bleed the LSVP if you have one, if in doubt, look just in front of the rear axle, if you have a steel rod, about 1/4" thick going from the rear axle to the frame, you have a LSPV, there's a bleed screw on it, the FSM says to bleed it last.
This combination of calipers and stock master will give a longer pedal travel, and ntsqd has calculated the ratio (leaving out the booster) to be 1:70, for his explanations, look on page two.
Thanks goes out to those who helped and supported me in finding my own stupid errors!
Hi all
I have searched and read what I could on the subject, it seems that others have had the same issues, and posted them, but there's no posts on solutions, I hope this ends up with me finding one, so my truck will be on top of it's game again, and others may benefit too, so here goes:
I'll start from the beginning:
I finally did get around to do something about my brakes, after seeing I had cracks in the discs and the pads where worn down.
So I took the plunge and bought and installed the following:
I went out to bed in the pads, and ended up with hanging brakes!
Well I thought it might be the master hanging, it looked old, and I had a new one on the shelf, so in it went.
I couldn't get a good feel, the pedal was soft, and dreaming of locking up the front? no way!!!
So I bled gallons through the system, but no improvement. Read about bench bleeding the master, did that, I thought the LSPV could be flushed by running enough fluid through it, since the bleeder looked really rusty, but got wiser on MUD, so fixed up another LSPV and installed that, but its not any better, and I'm at my wit's (and search's) end!
But my brakes are still not good!
List of what I've done:
Could it be, that having the 4 X 45mm S13WB calipers just took it over the top? Most 4runner calipers are 4 X 43mm, S12 casting...?
My next step could be to get a new 15/16" master, or maybe a 1", and a new booster, what's the verdict?
Hi all
- 1995 4runner/T100 S13WB calipers with 4 X 45mm pistons
- New standard discs
- Hawk LTS pads
- Replaced discs (standard 20mm)
- Replaced calipers (4runner 4 X 45mm S13WB, originally used on 25mm discs)
- New Hawk LTS pads
- Bled the system, using "two guy" method, LR, RR, LF, RF
- Mounted a new master (22mm, 7/8" bore)
- Bled the system
- Bled the master
- replaced the LSPV
- Bled again, thouroughly! MC, LR, RR, LSPV, LF, RF, LSVP and again at least 5 times, omitting the master.
- Took the master apart to check it, no issues
- bled the master again, used 60cc syringe to create a vacuum to be sure ALL air was out of the master, before attaching lines, then bled the rest, LR, RR, LSPV, LF, RF, LSVP and again at least 5 times again.
