Finally got some time to plug the numbers into my spreadsheet, overall system leverage ratio as reported is 70:1. The booster throws me a curve as I'm more used to non-boosted brakes, but going bigger on the m/c bore is the wrong direction. The booster may allow going to 1", but bigger than that is very questionable. The change in line pressure btwn the 7/8" bore and a 1" bore at the same pedal effort is 23% lower. Big change from seemingly not all that big of a bore size change.
Old rubber hoses can expand under pressure, wouldn't take much to make the pedal feel mushy. Replacing the rubber hoses would be high on my list, but I'm leaning towards entrained air somewhere. Volume of fluid pumped thru the system is no guaranty that you got all of the air out. That the brakes get better by pumping them is a classic indicator of air in the system. The most ideal flush/bleed method is to pump fluid in from each bleed nipple. That is how aircraft are done. Next best is probably a professional power bleeder, and then after that something like the peanut butter jar power bleeder.
