The right side comes off okay, is smooth, lot of shoe. Fronts and the right rear appear to have been a cheapo brake job that ignored the wheel cylinders, master cylinder, frayed rubber hoses. But the left rear drum is stuck like glue. There are two holes in the drum, one appears to have been where the attach fastener was located in 1979 when it was built. The other hole is much larger. Regardless, positioned in the right place I can pass a #3 Phillips through to contact with the backing plate. Shoes are adjusted to allow free rotation of the axle assembly. But it ain't movin'.
