Build Box Rocket 1985 Hilux
Great project, you are ahead of me on my swap, just got the 3.0 drive train pulled from my wife's '88 4Runner, will be keeping an eye on your progress and really interested in the final rpms at highway cruising spped. Hope to not have to re-gear my diffs, rubber overdrive might come into play....
After waiting through Covid delays on parts and a few hiccups with the new engine harness we're making progress again. Now that we've got the harness, we can get the injectors and starter plugged in and the intake reinstalled. We've got a 1KZ radiator going in and will need to do a bit of creative hose work for the coolant hoses. We're getting really close to firing this thing up finally!
Untitled by Adam Tolman, on Flickr
Bit of a thread resurrection. I'm sad to say that this project turned into a bit of a nightmare. The shop I had helping me with the 1UZ swap...let's just say didn't go as planned and I have brought the truck back home with essentially no progress from the last time I posted. Needless to say it was one of those shop horror stories you hear about and I won't be having the shop involved moving forward.
With that said, the remaining things to get this truck back on the road are going to stretch my skillset. So I'll be asking for lots of help along the way and hoping the collective knowledge of the forum can help me accomplish what I didn't think I'd be able to. The motor is in the truck and wired up and it's actually fired up once on a spritz of ether but that's it.
Priority 1 is the cooling system. There is VERY LITTLE room in front of the motor and using a factory radiator is just not possible with a puller fan. Actually we could, but if I ever wanted to change the serpentine belt I'd need to pull the radiator. We've gone back and forth between doing a rear mounted radiator in the flatbad and modifying the front clip to allow for a normal front mounted radiator. I think we've settled on modifying the front clip so we can get a good size radiator up front to cool the V8 and still have a good shrouded fan and not have to pull it to change belts. It will require losing the hood latch and going with some hood pins but I think it's a reasonable concession for keeping the radiator up front.
Priority 2 will be the fuel system. The original tank was rusted badly and not worth fixing. I have a replacement factory tank but it's a couple gallons bigger so fitting it is going to take some minor fab work. The flatbed has been removed and the rear frame is open and ready to for mocking up some new tank mounts. Working with the fuel system is one of the areas I just don't have much experience at all. I'm hoping to find a good in-tank pump and sending unit setup as well as bend up all new fuel lines that are bigger than the tiny ones that were part of the original 22R. I've looking through other threads that I can find that have useful info and I'm trying to learn what I can but I'm sure I'll have loads of questions.
This has been a project with my son who has been gone for the past couple years on a church mission. He came back last summer and now he's engaged to be married in April so I'm not sure how much help I'll get from him since he's already into his college education in a different state. But I'll use him as often as I can get him around.
the easiest way to do the fuel system is just with stock stuff. efi tank, pump and hard line. pretty sure the hard line is still available new. or at least something compatible.
afaik the bigger tank should just bolt up. at least it did for me in my 85 4runner.
there are parts available if you need to adapt anything to AN as well.
and do you not have any fuel pump wiring either ?
I believe all the wiring is still there for the pump. I'll take a look at just getting my hands on stock stuff for the pump and lines etc if you think it's adequate for the 1UZ? It would definitely make it easier.
i believe so. worst case, you have to go to a different pump.
edit:
ok so a couple seconds of research. the lexus pump didn't want to cross but the v8 tundra crosses to others.
so you should be gtg.
The flatbed has been removed while we rework some of the rear chassis stuff. Replaced the rear tube crossmember to fit the larger fuel tank and will be relocating the shock mounting. I'll be making some minor changes to the flatbed over the next little bit.
Earlier this week I took the truck to a local guy that more experience with the 1UZ swap to help me get it finished up and running. Still some things to do but it's not far away now.
Looking good. Love that it's getting towed by a Yukon XL. Got a soft spot for those early 90s to mid 2000s Yukons and Suburbans, especially the 2500 variants
haha. I'm shocked the Yukon is still working. It hasn't had an easy life, but it keeps on ticking.
Are you keeping a/c in your truck? I am working on a 1986 4runner 1uz swap and have been working on brackets to put A/C compressor on the right side where the power steering pump was. This is my first stab at it I'm going to try and reposition compressor closer to the block.
A:C bracket.webp
Are you keeping a/c in your truck? I am working on a 1986 4runner 1uz swap and have been working on brackets to put A/C compressor on the right side where the power steering pump was. This is my first stab at it I'm going to try and reposition compressor closer to the block. View attachment 3737929
Cool. That bracket is looking good.
The goal is to keep the AC. The compressor is still in the original location on the other side. I plan to leave it there if possible so that a factory drive belt will work and be easy to find if I have a belt fail somewhere. Trying to avoid having to source an odd belt. Might be over-thinking that but I don't see a reason to move the compressor on my truck. I will have to have custom AC lines made that will have to be longer that what you will be able to do though.
Haven't updated this thread in quite a while. This has been a slow project but it's coming along. Fuel system is in and complete. Cooling system is sorted and complete. The pics are before the braided lines were installed for the radiator but those are all done now too. Radiator is a 3-row aluminum unit for a 4.0L Jeep XJ with triple fans, and integrated trans cooler. The bulkhead of the flatbed was cut out so its open for the entire surface of the radiator. There should be enough air between the radiator and the cab for the fans to pull what they need to keep it cool.
The NWToys tube headers were pulled and replaced with some log style headers. Clearance for the tube headers near the frame just wasn't enough so that was part of the reason for the change. Also, learned that the tube style headers work pretty well if you are also doing forced induction but can actually be lower on power compared to the log style headers on a naturally aspirated 1UZ so that was another reason for that change. Still need to have the rest of the exhaust built but that will be one of the last steps.
Decided to use a universal gated shifter for the A340F trans. Working on getting that fitted now. It will require some modification to the tcase shifter but that's fairly minor.
Air intake is mostly done.
Did an EGR delete on the motor.
There's always a bunch of small things when you get near the end and it's getting close to that point but I can almost see the light at the end of the tunnel.
