Back in post 592 @scottryana posted this:
Bolt-on Turbo kit:
Turbo: Borg Warner Airwerks 62mm
Forged CNC compressor wheel and Inconel Exhaust wheel
Journal Bearings
4" inlet, 2.5" outlet with 3" marmon flange downpipe
Max flow 78lbs/min
Wastegate: Tial Sport MV-R 44mm
Turbo header: Stainless steel J-pipe, single scroll T4 flange
Intake: Stock airbox
Dowpipe: 3" marmon flange, with bungs for AFR
Hoses: Crimp fit AN lines
Computer: Stock OEM
Injectors: Stock OEM 315cc/min
Fuel Pump: Stock OEM
Fuel Pressure Regulator: Stock OEM
Intercooler: Still working on this - going to try for A/W direct fit between turbo and TB.
Transmission: Stock or Shift kit up to end user. I recommend Transgo shift kit.
As this thing keeps getting closer, I was curious about the stock injectors and fuel pump. Should we upgrade these for insurance? My experience with injectors and fuel pumps on my SC Tacoma suggests bigger is better. If we do upgrade, can we run a little more boost on the stock computer?
Bolt-on Turbo kit:
Journal Bearings
Max flow 78lbs/min
Computer: Stock OEM
