- Joined
- May 3, 2013
- Threads
- 64
- Messages
- 542
- Location
- Upstate South Carolina
- Website
- www.nexgencontractors.com
Yes maybe I should have been more clear and just asked for the model turbo lol. This map shows I would be in the .72 efficiency range. I am looking for around 55 Lb/min flow and 2.2 P/R. I would rather sign up for the whole kit with the turbo included just wanted to make sure it meets my needs. I was also looking at a Garrett GTX3582r or Borg Warner S400SX3 which would meet my needs more efficiently.HP range of the turbo is not an accurate way of measuring flow. This turbo will flow around 75lbs/min at an PR of 3.8 but it will be pushed no where near that. I have attached the compressor map which is the best way to judge flow. You have to look at the flow at the PR you will be running.
Boost range? boost is a measurement of air flow restriction of a particular engine. This turbo maxed out on a 1.8L could probably push 50psi on an 9L engine It might only muster 8psi.
The exhaust A/R is 0.88.
