Well many of you ask why my V8 swap and my rear bumper project are not progressing. One is b/c I am a busy dude a the other is b/c those projects cant progress until I started this one.
So you westerners dont know what rust is. In ohio we are in the dead center of the "rust belt". the winter climate here is in between freezing and thawing constantly so the roads require extra salt to keep all of ohio crappy drivers on the road. My 80 has been a native ohio truck all its life and has been under attack from the road salt and liquid ice melting chemicals for 13 winters. I knew I had to get the rust under my truck in check or major damage to the frame and floor would soon result. I am not one to half ass something nor do I believe in miracle rust eating paints. So I decided to attack the project in halfs. I tore the rear axle out and sandblasted it to perfection. Why did I not tear the axle apart 1st? B/c toyotas seals are way better that duct tape. I restored a few axles in the past that I stripped down 1st and it is near impossible to keep sand outta the housing especially if duct tape is involved. So my new approach of sandblast and paint first then dissassemble regear and rebuild has to be a better way.
I also used the opportunity of having the axle out to yanks the gas tank and sandblast bad areas of the floor and frame. The reast is wire wheeled and lacquer wiped. Then a near $100 per quart etching primer is sprayed on to seal the clean steel. I will put a topcoat of low gloss black or gray afterwards.
I will post up some more pics tomorrow. for now you can see the spot sandblasting I did on the frame and body. I did lay on the two part etching primer today and will post pics of it. more to come.. Kirk
