I have searched through many threads on this topic and even read through coolermans web page (great stuff by the way) and seem to be having a similar problem but stightly different than most I have read. I have a 76/77 40. My problem is only with the blinkers everything else works fine. I have checked the switch and have continuity were I should when I should. I have 12V at the green with blue wire when the ignition is on but when you turn the switch for the blinkers on either side the voltage drops out completely. All other lights work perfectly (running, brakes, and even the hazards). I am assuming that I have a short to ground somewhere in the harness but was hoping that someone might have some advice as to something else that might be causing this problem before I go pulling the whole harness out. Thanks
