Usually it's the small spider gears that slip and break and then the chunks from that go through the ring and pinion, breaking those. The design of the carrier, r&p, and the spider gears allows for some deflection under certain circumstances. The deflection occurs much more easily with the 98/99 only having 2 spider gears, not so much with 00+. The "best case" break is that you shear teeth off the spider gears only and the ring and pinion remain undamaged. Then you only have the cost of a new carrier or ARB. If the spider gear parts take the ring and pinion with them, then you get new gears too.
The ARB replaces the whole spider gear assembly with a much beefier unit The ring bolts to the ARB carrier and doesn't allow for the slippage the OEM set up does. Plus, you get a fast acting locker that is a HUGE traction assist and keeps you out of those situations where you're bouncing and slipping.
https://forum.ih8mud.com/showpost.php?p=6797577&postcount=2
