steering shaft, before
After.
Next up DOM crush sleeves.
Another small step in the right direction.
3 of 4 DOM crush tubes needed for chassis in 60 -40 series power steering swap.Let’s play name that part…
Any guess what these are??? And what they are for?
Close enough… 3/3 DOM crush tubes for a Scout II P/S swap in a 40.3 of 4 DOM crush tubes needed for chassis in 60 -40 series power steering swap.
I’ve just finished my 60ps swap on my 47.Close enough… 3/3 DOM crush tubes for a Scout II P/S swap in a 40.
Good to keep in mind… the Scout arm is crazy long, and so far the Jeep pitman arm that’s going to replace it is sloppy loose. I could easily see mocking it up without tightening it down and then living to regret it.I’ve just finished my 60ps swap on my 47.
I fit my sleeves super tight and I did manage to get a bit of weld on each one on the inside of the chassis for retention.
fyi. Make sure your pitman arm is torqued on the sector shaft when you fit up the box and check for clearanceDon’t ask me how I know this.
cheers
Crusty
Takes one to know one…@bikersmurf - you just hit 10,000posts! A honest to goodness mud addict.
Are you replacing that pitman arm? How does it line up or are you getting a
dropped pitman arm?
dropped pitman arm?
forum.ih8mud.com
