Good score!
If it has a metal socket it would be a ‘79. Plastic would be ‘89. In the early 90s they stopped using the MFG/Date code.I've got an FC9 of the front of mine. I've also got a "plow version" which doesn't have the free spool release lever. Just power-in, power-out.
I’d agree it’s overkill for most stuff. Cutting down the winch mount involved cutting through more than 7’ of 1/4” steel. At times like that, a 7” is great. I’m sure I’d have burned up a couple cheaper grinders before I was done. One 7’ cutoff disc cut about 6’ of it. I think I went through 2-3 4.5” discs to finish the cutting.7” is overkill for almost everything…
A decent 41/2 or 5 (Makita 9005b is cheap and tough) should last for many many years with home use.
Cambodian tire cheapies with a warranty are a viable option if you’re down for repeated trips for replacements. Just make sure you finish your big grinding project before the warranty expires.
Stay away from cheap grinding discs… you get what you pay for. Anything 3M or made in Germany is a sound choice.
I spend a lot more time with grinders than I’d like to.Maybe one day I’ll be able to put down some decent welds.
8274 just looks right on the front of a 40. Excellent choice
Cheers
Crusty
Yep all true. I buy the cheapest disks I can find and they still last ages.You not supposed to use it like a hammer
Just relax and let the cutoff wheel do the work, if you push it into the metal it won’t last long. You should be able to cut several feet of 1/4 inch with a 5 inch quality cutoff disc.
Roughed out a snatch block for my winch last night with my grinders, didn’t use 1/4 of a cutoff disc doing all that cutting.
