My plan is to fit an aux tank above the spare wheel, perhaps 25 litres (have to work it out with dimensions), would like a dual fill nozzle or may divert the OE fill to the extra tank and gravity down to the OE tank. I have the overhead console with the altimeter and fuel gauge, I would be looking for a simple sender to work the overhead fuel level gauge, I would have the two fuel gauges reading at the same time.
Any reason for NOT doing it that way as custom fuel tanks with simple connections seem cheap enough, in particular as the car is diesel it should be no problem?
If anyone is interested the older XJ Jaguars with were fitted with twin tanks but only the one high pressure pump, simple changeover feed/return valves were used, just the click of one switch changed not only the tank being used but also the feed for the fuel gauge, this is an idea for those who had mentioned about the fuel safety 'cut off' point made earlier. I had many years with Jaguars and the system was very reliable if you used decent quality components.
Anyone have an idea how the OE console gauge works on Land Cruisers? It does not appear to be the typical earth return unit but seems to be a stepper motor design?
regards
Dave
regards
Dave
