so, I have an aftermarket GT Grant steering wheel and aftermarket air horn on my FJ40 and the horn wires I run up the steering column....
BUT the problem is, the only way to get the wires to the horn button is by a little hole at the backside of the Grant wheel where it mounts to the steering column (the only open hole). BUT, when I run them through said hole, over time the turning action just rips/shreads/mangles the wires every single time. I have tried wrapping the wires in tape like 5 times to make them beefy - does not work. I have tried on top of column or below column - same outcome. I hae tried split loom to protect the wires - eats through that. Since there is only 1 way into the steering wheel via that hole and to my horn button, it seems no matter what that in the end the wires get fowled in the turn signal, cut, shreaded, etc. There is no hole in the center bolt or in the steering column to run the wires straight up into the center of the wheel, so what am I supose to do?
how is it done on the original FJ40? where do the horn wires go. is there something there (nuts) I am supose to attach to so that the turning action does not fowl the wires?
I am stummped and I am tired of replacing fowled, cut, mangaled wire or fighting the wire wrapping around the steering column.
What can I do?
What can I do?
