- Thread starter
- #1
Hi all! -
So I have owned my FZJ80 since 2000, and I didn't have a boat then & liked trails (and didn't mind the work to keep on top of the use) - but the older I get the less I really USE the 80 and spend more time & will continue to boat more.
The boat is a 21' Wooldridge & weighs ~4250-4500#'s when loaded on trailer & with all the gear in it/tank of gas (77 gal tank, usually half full)
I don't mind the 80 for acceleration, but the lift & the solid FR axle, plus the 35" tires make for a less than perfect tow vehicle, and the trailer has mechanical / inertia brakes (no use/need for a in-cabin brake controller, unless you can retrofit electric brakes easily - and between the 35's and that brake style (tandem axle trailer), it would be more than the 80 can stop in a panic situation.
So, all the above said - and enough of you having had a 100 before getting a 200, which would you rather tow with?
I would like to hear if one drivetrain is superior (and which part -motor, trans, ???) - or just exactly why you like one over the other.
Also, just where does the Sequoia fit in the lineup?
Is it a value towing gem (relatively cheap, lots available) or waste of money/mashup of parts?
Is it as reliable as a Landcruiser?
I do plan to keep whatever my purchase for as long as I've had my 80 (or longer) - so money up front isn't a big deal as long as it's smart money.
On the topic of smart money, has there been enough 200's sold for there to be much dealer support, or is it even a small struggle for any particular parts in your experience?
--(Might be a question either Dan or Onur would best field ???)
If I ditch the 80, then for versatility a OME lift & ~33" tires would be the max I go & then it sounds like Bilstein is the shock of choice - correct?
I would have a 30-35K budget (without getting a loan, why the word budget is there) plus if I was to sell the 80, then all 80 money would go to new Toyota. It seems like a 2008 & a few newer ones fall into the ~$32K asking range (Would fly anywhere to get one in the 48, but won't look at any in the salt belt, no matter the 'deal')
I would like it to have the rear diff locker as sometimes the "boat launch" is somewhere we can stab the boat in from a sandy bank, so especially coming out I'd like the locker & being able to control the transfer case like you can in a 80, if possible.
Thx to all who read all that, and any who can give advice/experience.
