semlin
curmudgeon
has anyone found a nice tidy bolt location to ground their winch? I have lots of ground cable to work with and would like to find a nice tidy foolproof ground spot.
And every ohm counts in a high current applications like a winch or starter. Because voltage drop equals current (amps) times resistance (ohms law), then you really need to minimize the resistance in order to get maximum performance out of the device. Say you've got 0.02 ohms resistance between the power source (battery/alternator) and some device that draws 10 amps. This is a reasonable resistance value if the path to ground goes through the steel frame/body and a couple of ground straps, especially if one of the connections is corroded a bit. 0.02 x 10 = 0.2 volts, so the device is actually getting fed with 11.8 volts - not bad - most any device will work just fine. But if the device is a winch or starter drawing 100 amps (a conservative value), then that voltage drop due to resistance becomes 2 volts and so the device is now getting only 10 volts - or 83% of the nominal supply voltage. Definitely not good if you want the winch/starter producing all the torque it can. So grounding direct to the battery with copper cable is the preferred option in any high current application.
napa. they are in their beldon catalog.
Nice. Thanks for that.
I went into the Napa store in Monterey and the clown behind the counter told me they did not carry those anymore, so I settled for some inferior clamps.
That really irks my noodle.
