6 months into LC ownership and I’d like to build up a bench stock of common parts and pieces that are nice to have on hand. Could we get a thread going here to help me and others out? Thanks!
CVs, tie rods, water pump, thermostat, belts, just picked up an alternator, any and all gaskets and O rings you can think of, mass airflow sensor (has come in clutch more than once), lots of fluids, spark plugs, one or two coil packs.6 months into LC ownership and I’d like to build up a bench stock of common parts and pieces that are nice to have on hand. Could we get a thread going here to help me and others out? Thanks!
It's a great rig for sure! Here's a solid place to start:6 months into LC ownership and I’d like to build up a bench stock of common parts and pieces that are nice to have on hand. Could we get a thread going here to help me and others out? Thanks!
Wow!CVs, tie rods, water pump, thermostat, belts, just picked up an alternator, any and all gaskets and O rings you can think of, mass airflow sensor (has come in clutch more than once), lots of fluids, spark plugs, one or two coil packs.
At least that’s what I’ve saved up, I’m sure others will have much more comprehensive collections.
Oh starter… that’s not a bad idea.. should have learned from my 100 hahaWow!
I’ve got some coils and plugs and O2 sensors (kept when replaced).
Two cvs (kept when replaced, didn’t need to replace)
One starter
Several boxes of odds and end from various past projects
Have some interior trim and hatch struts in a box to put on, just haven’t made time.
Awesome! Just the thread I was looking for. Thanks for the nudge in the right direction.It's a great rig for sure! Here's a solid place to start:
Stuff to keep on the shelf
Some stuff is worth keeping on the shelf. For me what makes the list are small parts that could shut down work if needed (oil drain gasket), or stuff that is cheap and might make work easier if we had a handful sitting around to be used when needed (the clips that hold the fender skirts in)...forum.ih8mud.com
