So, it looks like my '78 brake booster is finally giving up the ghost.
This morning I found some fluid leak under the 40 and it turned out to be brake fluid. The leak is between the master cylinder and the booster. Order the master and will come next week. I start the engine, let it idle awhile, turn the engine off and after about 30 seconds I hear a noise like boiling fuel or a vacuum leak.
I open up the hood and the sound sounds like it is coming from inside the booster with a "crumpling" sound at the same time. I put a mechanic's stethescope to the booster, intake manifold and carb and I can't hear anything through it. But it does sound like it is in the area between the booster and master cylinder.
What do you all think, booster?
