Axle/Suspension Options (1 Viewer)
Raleigh, NC
Hey Guys,
Posting this in this forum, because there does not seem to be much info or interest in these topics on the regular 60 forum. I have a few questions and I'm hoping to get some education.
Current set up: 80-series rear axle. 60-series axle up front with tundra disc brake conversion. Both have 3.73 gearing. I am sitting on OME suspension (springs and shocks). 265/70/17's. LS-swap.
Axle Questions: I would like to know if my current set up will work and have some other questions.
1: Will my current set up work if I got up to 35's?
2: Options for beefing up my axles and keep my front discs?
3: Can I upgrade to Dana 60's? It seems none are specific for Toyota applications. However, I know this would provide me plenty of options if I decide to BIG one day.
Suspension: Since I do 80% on-road, I want to keep it safe.
1: Is 3/4 link safe and manageable with a pan hard bar?
2: Is a radius-arm set up ideal? Is there a kit on the market?
I'm welcome to any input or questions you all have. I'm looking to learn, so that when I make a major investment, it is not a waste of money. I likely won't be able to do this myself, so I am looking for some shops too. If you know someone I should reach out to, please let me know.
Thanks,
JB
D60 does not makes sense to me unless you are gonna wheel it hard .. RCV to start with, plenty info around here to beef up your front axle ..
I would install 4plus' front axle housing spacers on each side of your front axle to give it more width and then put some RCV axles in it. For suspension I would just do a 2" body lift to go to 35s. Link suspension is nice but if your doing 80% on road you can make your sua setup work well with some tweaking. Use long 6 or 7" shackles at a 45 degree angle at ride height. You could use radius arms from a fj80 with not too much effort.
What the hell is RCV?
Would I need to add a high steer kit if I go bigger? SOA?
Thanks!
