Axel not pulling out? (1 Viewer)
JDNs78FJ40
Draper Utah
Starting to rebuild the knuckles on my 78 FJ40. I’m in Utah so I’ll be purchasing the rebuild kit from @cruiseroutfit. Had the diffs sandblasted to remove most of the old grease and gunk. I’ll use Por15 on all the components. Is there a secret to pulling out the axel? It seems to rotate very easily but will not come out? Any suggestions.
The birfield has flat spots 180degrees from each other. Try to align these flat spots with the trunnion bearing holes. It should come out.
Sometimes it takes a bit of wiggling while you pull. If there is no damage to the bell portion of the birfield or the underside of the the trunnion bearing pockets, it shouldn't be too difficult.
Awesome! Glad that worked out for you.
