Do you have technical proof that WS is not good fluid? It’s synthetic fluid made by Mobil1.better be using something better than Factory WS then.
Really? I would be very surprised if Toyota WS were made by Mobil 1. Can you cite a source for that info?
TIA
Mobil ™ ATF WS
Mobil ™ ATF WS is an exceptionally high performance lubricant that meets original equipment manufacturers' specifications for use in certain slip-controlled lock-up automatic transmissions.www.exxonmobil.com
BobIsTheOilGuy has several threads on it too.
I agree, but depends on the towing vehicle, and the conditions. 4600 lbs at a 12% grade for an extended time can be quite rigorous.BTW towing 4600lb is nothing...
I never said it was not good fluid. It is good fluid.Do you have technical proof that WS is not good fluid? It’s synthetic fluid made by Mobil1.
How are you defining “sustained”?I never said it was not good fluid. It is good fluid.
So as you asked: "technically" Mobil1 is a product, not the manufacturing company. Exxon Mobil is the company......Toyota does not rely solely on XOM to make their Toyota branded WS fluid..........which brings me to your other claim of "its a synthetic fluid":
PdsDetailsPage
Mobil ™ ATF WS is an exceptionally high performance lubricant that meets original equipment manufacturers' specifications for use in certain slip-controlled lock-up automatic transmissions.www.mobil.com
Where in this publication does it state "synthetic"? It does not.
I was remarking on the screen shot of 253f temps at the torque convertor. This temp, although well below the flash point of WS, is not good, really for any fluid, but at those sustained temps, the additive package in factory WS will not last long, and more importantly, neither will the rubber seals.
WS is clearly a good fluid, but there are fluid out there that are "more durable" under those temps. Like Amsoil, HPL or even Valvoline Maxlife, which all WS rated fluids. Dexron 6, which is backward compatible with WS are, by spec, is a synthetic blend, for whatever American marketing allows something to be described as "synthetic", which is less than 10% man made materials BTW.
253 on AT temp is not safe
forum.ih8mud.com
Toyota doesn't seem to think it's bad to run the 6 speed AT at temps below 270F, apparently.
This is key. If these trannies were running at these high temps all the time, they would not last to long99.9% of the time, the tranny is sitting at or under 200 degrees. I also follow the severe fluid change intervals.
Interesting, so in addition to the air to fluid cooler already there, niceI've added an aux aux tranny cooler.
Thanks.Welcome to the boards.
Sustained meaning for long periods of time. As in perhaps over a few minutes of climbing temps, to near flashpoint.How are you defining “sustained”?
This is key. What we are looking at is two temps, one is the convertor, and the other the pan. Here, it looks like the pan is 29 degrees cooler than the TC. I would say that the pan temp takes quite a while to get here, especially at 45mph or so, do to the removal of heat in the radiator and aux cooler.....however....there will be a time, when thermal runaway takes effect, and the system can no longer remove the heat. At this time, tranny failure is immenent if not left unchecked or stopped. The hotter the tranny, the higher the oxidation of the fluid's additives, and so on. It is no different than any other transmission in any vehicle, there is no special wizardry to it. WS is a good fluid, but these vehicles, as robust as they are, are not without boundaries. Amsoil for instance, or Maxlife, have a much higher flashpoint than WS, which is a semi synthetic blend. They will resist oxidation longer, and therefor protect the tranny longer, was my point.not for long drawn out periods of time.
Sure. At temp 2 is the TC, as it sees intermittent heat quickly, especially when not in lockup. But the pan temp and really the ration between the two temps is really where the danger is. A near instantaneous heating of 30 degrees is nothing to shug off. I think it is good practice keeping the temps as low as possible, under 230, just for the overall life of the tranny seals, which is really what makes it all work.I’ll proceed and might see 20-30 seconds above 250° but never more than 260°
This is because you are nearing the flash point of Toyota WS fluid, 328f. Flash of course is when the fluid starts to vaporize and become ignitable. This type of thinking is like jumping of a building, the ride is fine, the whole time, until you reach the ground. "bad" meaning it wont burn the truck to the ground, but they will be selling you a new tranny soon. Drive around at 270 for a few days and see how much they think it is OK. At the moment of flash temp, seals are destroyed.FWIW the AT temp light comes on at 304F and shut off around 270F. So Toyota doesn't seem to think it's bad to run the 6 speed AT at temps below 270F, apparently.
Sure it get it. And I am sure that is the case, especially when the tranny is connected to a thermally opening bypass, that only lets fluid to the aux cooler at whatever temp.For context, I'm not advocating this as common or okay to regularly see temps this high and most won't when towing with the 200-series.
Any reply @04UZJ100 ?I never said it was not good fluid. It is good fluid.
PdsDetailsPage
Other than doing a drain and fill myself, what's the general consensus on full fluid changes when under 100k miles? I'm thinking that if my 230k mile LC can handle a fluid flush, why can't a 93k mile LX? Would there be any significant benefit by doing, or not doing, the full fluid change?
First off your terminology may be a factor here. What you really want is a Fluid Exchange, not a flush. The latter can (but not always) mean a machine forcing fluid and maybe a solvent through the transmission to clean things out.
Second if you show the Toyota dealer that it is the same transmission (the AB60F) as installed in a tundra, or sequoia, perhaps they’d be more accommodating. Or to take that further, it’s the exact same Toyota part number as in a Landcruiser of the same year.
Third, if you have to do a fluid exchange yourself it isn’t very difficult. Around 100k is as far as I’d push the factory fill and you’ll definitely prefer the appearance of new fluid vs what comes out. I did my 200’s first fluid exchange at 105 and am very glad I did.
Yeah worth a shot. To be clear shops will usually still use a machine for a fluid exchange but the idea is there is no more force than the fluid coming out of the transmission, and only fresh fluid going in, nothing else.Thanks, that makes sense. I'll swing by the Toyota dealership and talk with them in person, it might go a bit better that way. If they still want to pass, I'll talk with the Lexus dealership to make sure we are on the same page with the terminology. My 100 had a fluid exchange performed, not a flush. I'll update my previous post.
I don't mind doing the simple drain the pan and refill with what came out myself but time isn't on my side lately. I'd prefer to just have the fluid exchange done at a dealership and go about my day.
