Are the metal brake lines in a metric size or standard ?
Pretty sure they're metric. Take a look through this thread.
The replacement brake pipe i used was rwgular 3/16 copper/nickel but the flare ends i used were metric (M10x1)
I can't speak to the 80 lines, but I'm having uncomfortable flashbacks to the last time I used a tool like that. I don't know... maybe the one I got was just junk, but I'm prejudiced against that style entirely.
SuperFastMatt has a good brake line video, though I'm still not sure it solves your metric or standard quandry. Next time I have to do hard lines, I'll be picking up the tool he uses.
I've just replaced and built new lines on my 80 using 3/16" copper line from Fedhill
I used this flare tool Eastwood Professional Brake Line and Tubing Flaring Tool - https://www.eastwood.com/professional-brake-tubing-flaring-tool.html but you need a vice to hold it and it may be available cheaper through other vendors. You use the 4.75 mm dies.
After I cut the line I use a deburring tool to clean the end Eastwood Tubing Deburring Tool - https://www.eastwood.com/eastwood-tubing-deburring-tool.html
Finding 10 mm nut size brake line fittings of quality was a challenge Good source for brake line fittings? - https://forum.ih8mud.com/threads/good-source-for-brake-line-fittings.1361936/ I bought a selection from @cruisermatt
I though copper brake lines were a no go?
What size line is used in the 80 series ? Metric or standard size ? What type of double fare is used ? iIs it a sae inverted double flare or the Din bouble flare ? Thanks
I use this tool and carry it on trail runs.
double flare tool
Easy to get perfect double flares and can be done with only 2 hands.
And use these nuts
brake line nuts
Okay I really like that setup . So it looks like it can make 2 different double flares , Which one do I need to us ? Is the 3/16 - 4.75 mm the correct tube size that fits inside it for the 80 series ? What size tube is used in the 80 series Metric or standard ? It seems 3/16 and 4.75 mm are interchangeable is that correct ? I want to keep this tool with me in the truck also along with some extra tubing and some m10-1.0 fittings and connection piece so I can cut and replace a hole in the line if need be . Do you know what piece I would need to connect 2 m10-1.0 male ends into ? I found this unions on amazon . It says
  • For 3/16" tube
  • 10 x 1mm Threads
  • Using Inverted Flare fittings . Is a double flare the same as a inverted flare ? Will these unions be the ones I need to connect to 10x1mm males together ? Thanks
Amazon.com: The Stop Shop Inverted Flare Unions for 3/16" Tube with 10x1mm Threads (Pack of 2) : Automotive - https://www.amazon.com/Inverted-Flare-Unions-10x1mm-Threads/dp/B01N6ZWCAR/ref=sr_1_22_sspa?crid=EPVYRBXBETX0&dib=eyJ2IjoiMSJ9.IYfAjKibKGziNSKZoylfBwyEcf0EsGkTN0FRwcQOJ059_J9-ftYnEcaWbOAxL-JUsnShmCiP3rDd1FkJjkjeWXdqRvkNwWX2LhGCidYICjTb3TDXUtd8ZvPFSMjCuJhRBZYEmOeETOSQpoXQS4PSgehtZCncP1gVlBdBc24GK4mt5BK7J2I_g30nHgPXbIvLVohKydyRZl3azvEIZ3ujAwM-m_0Gm5tp4f1yxcbSH5I.4r1VWBDOm6fp_Yi4_yataUpeua1WsdJjqf_5Lj5Fvz4&dib_tag=se&keywords=10x1mm+union+for+brake+line&qid=1751519927&s=industrial&sprefix=10x1mm+union+for+brake+line%2Cindustrial%2C124&sr=1-22-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9idGY&psc=1
