I've used both, sell both, and currently use the Stauns. I have mine set to 16 psi. If I want to go lower I'll them manually release a psi or two out. I prefer the Stauns because they are faster.
And to Badlander - terrain, your tire, wheel, and how your tire matches to your wheel will dictate where you air down to. The more you air down the more contact patch you get with the ground and therefore typically the more traction but also the more you risk popping a bead.
. I air down all of the time (8 trail days in November) so it's second nature, never drop them. I always carry spare caps and cores, just ask for used ones at the tire store, usually get a handful, free. The biggest issue I see with them is; lost caps when airing down, mud/dirt gets into the cores, when aired up they leak, so have to be replaced.
