There's enough meat on this topic of Apex Deflators that it deserves its own thread.
Screw on RCV (Rapid Connect Valve)
Install / Replace valve stem RPV (Rapid Precision Valve) in std length (which should work with most OEM wheels)
From the following discussion
It's actually crazy timing for you to mention this--I'm taking them off and swapping to the other Apex valve--the RCV, which just showed up today. I had the standard length and you have to buy a bracket/adapter that just holds the trimmed TPMS adapters inside of the tire. I've now had two of them break off of the brackets causing them to spin around loose until they eventually wear through and break completely and then none can read because one is broken. The RCV's are not nearly as quick, but they install by removing the valve stem core from the factory valve stem and installing the RCV in it's place. I'm now about to have to swap back and install 5 brand new TPMS sensors since they cut the original ones to fit on the bracket. If you can live with potentially replacing one per year I'd recommend them because they've been awesome other than a poor TPMS bracket design.
Apex RCV
It appears to be very timely that I asked.
I was thinking about using the strap method for the TPMS because the Apex relocate bracket looks a little suspect. However, I had considered the RCV because I can install myself. It is time for balance and rotate so either way, install is not a big deal.
My main gripe with my current setup is using the ARB valve removal tool to air down… it’s just a PITA getting the brass on your fingers and I had one stem not screw back in and it blew out in the Utah sand, I was able to get it back in but it highlighted the obvious worst case scenario with that method.
What are your thoughts on the strap method for TPMS? The speed of the RPV is a major factor as I’m also doing 2 camper tires but if it means adding the con of TPMS issues than the RCV would be best for the Cruiser and run the RPV’s on the camper where I’m using the screw on ARB TPMS.
Great discussion! Had me digging into RCV and RPVs all morning. I'm trying to setup another set of wheels and Iwantneed these!
Maybe this deserves a dedicated thread. @Romer ?
Looking at the RCVs, they add about 3/4" to the total length of the stem. OEM stem is about 1.2", +.73" = 1.93" I'm not sure I'm comfortable with that on the Tundra wheels I have as that'll have it closer to the face, putting it in danger of rocks. Whereas the normal length RPV will be about 1.62" total length.
