- Thread starter
- #41
Someone close this thread please.
So, are the hubs locked full time on a rig with Torsen transfer case?
Yes.
We are getting into semantics here, and labels given to a vehicle from the vehicle manufacturer.
In general, AWD vehicles (Subaru, FZJ80, Rav4, etc) do not have the option to shift into 2WD. The center diff is always engaged. The difference is on 'Full Time 4WD', you can actually lock the center diff to transfer power, rather than relying on a limited slip setup.
4WD, you can select 2HI, 4HI, or 4LO.
For the sake of this thread, the OP is discussing using a split case to 'put all 500hp down to all 4 wheels'.
My reply was based on him using a split case shifted into 4HI, putting him in 4WD at all times, and not the use of a 'Full Time 4WD' transfer case (80/100 series) to get what he's looking for.
Sorry for the confusion.
Buy a Jeep.
Locking hubs seem to be a thing of the past on 4WDs that have a Torsen in the T case.
Remember the "Wolf"??
Big block 502..
2002 Top Truck Challengers 1972 Toyota Land Cruiser FJ40 - Four Wheeler Magazine
[/QUOTE]The axles won't hold up long even if you find the tcase you're looking for. A customer and friend threw a 454 with a B&M blower in a 40 which
produced a bit more than 500hp. You'll be snapping axles and pinions. We stretched it and ran it through a built TH400 and Atlas
We build 35 spline Dana 60's and ran 42" swampers. He could be cruising in 4WD at 35mph and step on the throttle and all 4 tires would light up
and the truck would go everywhere but straight. Most of that due to tires I'm sure. The tall sidewalls on swampers would wrinkle up and unload at the slightest loss of traction
I've broke a dozen birfields, three semi float rear shafts and two full float rear shafts and a pinion with 2Fs and mild 350s. I usually run 60~70:1 final drives and all broke at a crawl speeds with very little foot in the pedal with the exception of the pinion and a full float shaft which was
in a soupy mud pit and I was on throttle. That was in a TBI 350, 200hp
