sleepycruiser
I will get by….I will survive -Touch of Grey LC200
Would need to fit in a 2011 LC200. If you have a padded envelope I can email you a shipping label and you can drop it in your mailbox.
Your 200 series is already prewired to have a brake controller installed. Look at this video I did to see where it's located and how to install a brake controller with the plug-n-play connector.
The plug and play harness you're referring to will be different depending on which brake controller you use. For the setup I used with the Redarc brake controller here are the parts you'll need:Correct, but I need the factory part that plugs into that. I found the vehicle side harness in there, but there is typically a factory harness that plugs into that one so you can hardwire the actual brake controller. I can order one, but thought someone here might have one.
