Any interest in an auxiliary AC condenser fan kit? INSTALL DIRECTIONS IN FIRST POST (6 Viewers)
I wanted to tap the signal wire in to a fuse in the engine bay but didn't like how the cover would have to be cut to allow the wire to come out. Snaking the wire out of the fuse box through the bottom with all the other wires would have required cutting into the harness sheathe and is a very small, fiddly place to work. It was tough for me and I have baby hands; I couldn't imagine what a PITA it'd be for someone with big 'ole meat paws. Mine doesn't have a CDS circuit, either.
Part of the design criteria is to make this easy to install without any splicing, cutting, or grinding. The only permanent alteration to the truck that needs to be done is to poke a hole in one of the firewall grommets to run the signal wire through. For me, it seems easier to run a wire into the cabin and use a fuse tap on the IGN fuse. Or whichever fuse you want as long as it's switched.
I'm also not using the compressor clutch to turn the relay on because leaving the fan on constantly allows the condenser to recover between compressor on events.
It only took me a very lazy ten minutes to install the harness, and I'm guessing mounting the fan will take 15 minutes or less, so I'm expecting total install time to be under 30 minutes. All said and done, it's just seven fasteners including the bolt holding the relay, a power, two grounds, and a signal wire, and that's it.
Lastly... I'm waiting on the parts, but I'm going to integrate a thermal switch to turn the fan off when the ambient temp is below 60°F so it's not running all winter.
At least on my 96, there is no CDS circuit, but the empty relay and fuse were there and labeled on the fuse box. The box comes apart with a couple small clips when unbolted and there's enough room to sneak some wire loom in - wasn't bad even with my ham fists. I did pull the charcoal canister for extra room though.
I'm triggering the relay with the unused "medium pressure" switch as described in Sumotoy's thread. The one extra trick I'm working on setting up is running that circuit through a repurposed rear heater switch. If it works how it should, the middle position will be disabled (for water crossings or whatever), the low position will run in "auto" with the pressure switch - and the low light will come on when the fan kicks in, and the high position will be full ON (with high light). Of course, I need to relabel the switch so I don't get it mixed up with the rear heater!
I was kidding though. Like I said, I wouldn't try to make that work in kit form: you want to make it easy for people, and this really wouldn't be for most. I just appreciate that it looks more or less stock and I don't mind complicated wiring. Automotive is elementary when you've built tube powered guitar amps.
I saw your post in UTOR just after you'd already got someone for testing, I'm within a half hour and would definitely have been all over that. Following along closely!
I finalized the pricing tonight, but won't announce it until I have supporting vender status. I will say that it's going to surprise a lot of you. ;)
The first beta test kit has been released into the wild. Interestingly, their AC wasn't fully charged (78°F vent temp before moving, 71°F while driving around the neighborhood), but they said the fan still made a difference. They're going to get their AC fully charged by a shop soon and will be back over so that I can get some more readings afterwards. But the takeaway here is that even if your AC isn't working perfectly, these fans will make a difference. It's encouraging that the improvements I saw in my truck weren't a fluke.
The second beta test kit will be installed next week.
for all the folks who have replaced all the cooling parts including a blue fan clutch, dont forget to change out the $57.00 fan. Mine exploded, it's the only thing I didn't replace and it just cost me $1,200 to replace all the cooling components again.
yep, been there done that twice. One time with my $2000 Ron Davis Unit. Don't forget to replace your fan shroud as well if cranks have developed, it will take out your radiator and fan blade with it.
yes, my radiator was a Ron Davis as well...:bang:
I spent the day fooling around with some tweaks to the fan and putting around the neighborhood got it down to this.
I've never said this about AC, ever... but it's too cold for shorts in there.
So what is pricing looking like?
$215 shipped within the lower 48; shipping elsewhere will be an additional charge. I want to get feedback from the two guys testing them out before I start making any, and I want to have some on hand before I accept any money. I don't believe in having lead times; when you order something, it should go out the next day, not the next week.
Also, what I'll be selling won't be able to get down to 39°F... that's with a boost converter running the fan at 19V. I'm going to be running mine through the winter at 19V and if it survives, then I'll be releasing that as an upgrade/option in the spring.
All right, got back from testing without the fan on. Same conditions and ambient temps as yesterday...
-128° to 70° took 1:43 (28 seconds longer)
-55° to 58° around the neighborhood (4° to 5* hotter)
-60° after a two minute stop (4° hotter)
-54° 10 MPH @ 1500 RPM. (6° hotter)
These numbers were roughly what I thought they'd be. While they're all mid single digits and I know that doesn't sound like much, the seat of the pants feel is very noticeable. Here's a shot of the setup. The wiring is still just crap wire I had laying around and is loosely zip tied in. I'm a retired aircraft electrician; I can do far, far better when I want to. ;)
where you got the brackets to mount this fan?
The second beta tester finally got installed today. As with both mine and the first tester, an immediate improvement was realized. And like the first tester, his AC wasn't fully charged (frothy bubbles in the view port), yet the fan still brought temps down.
My next step will be to assemble five kits and once that's done, I'll post a new thread with install instructions. For those that missed it above, cost will be $215 shipped in the lower 48; the cost of AK, HI, and international shipping will be on a case by case basis.
As the 1st beta tester with the poorly charged AC the fan definitely made a difference in traffic and around town driving even before I recharged the system. I got the AC recharged today and went for a test drive with Mandrake and was shocked at the change in temps. Obviously the recharge made a big difference but I’m running a completely stock & original AC system in my ‘94. Temp got down to 58 on the test drive. I’m very pleased with the results. After driving home and feeling almost chilly in traffic, I pulled the fuse on the new electric fan so I can compare the recharged system with & without Mandrakes fan running. I’m happy so far! Now maybe my wife will be willing to go for a ride in the cruiser with me!
And why would i want my wife to ride in my 80? That's crazy talk!
