- Thread starter
- #81
Why yes...I do have some updates. With the cooling package wrapped up, I moved on the last major fab project, the oil pan. I had a stark moment of common sense and asked the question, "why do I have issues when using the same parts I have seen other builds use?" This led me to putting the chassis on jack stands, removing the shocks and springs, and then cycling the axle. The tie rod does indeed swing up into the oil pan, but the epiphany came when I started auditing the bits. I realized there were no bump stop spacers installed. I did not install my lift, a PO did, and I never thought to check it. I have OME 3" lift J springs and can more than spare a bit of travel to protect the oil pan and the shocks. I glued up some wood blocks to simulate bump stop extensions, and jacked up the axle. I was able to lift the chassis off the jack stands and still have .75" of oil pan clearance. I called Slee and ordered 2 sets of 2" bump stop extensions. I will take one set and part them off at 1". I plan to stack the 1" on the 2" and have a 3" spacer, which gives me a comfortable margin. It is pretty easy to develop a 2G load on bottoming, and in extreme moments, a 3G load is possible if you really work at it, and 3" of bump stop spacer gives me a warm and fuzzy. Moving on.
