Not sure I have the typical leaks most folks have written about. Gear oil is leaking through the splines and dripping down the face of the drum. The rig is just sitting there ...and still leaks even in the cold weather. Can't imagine what it would do if the rig were running and the 90 wt oil was hot.
I can see the outer edges of the spline behind the castle nut and I am wondering if I got the wrong washer back on. Does the washer act somewhat as seal to prevent the oil from running out the splines?
The seal in the speedo housing seems to be fine.
Thanks for any help.
