Builds Another FJ68 Build (1 Viewer)
Working on steering lines and mounting reservoir
Slow progress, but it takes time to chase all the unwanted wires. About 95% done cutting down the factory wiring harness. Then floor will be prepped and lizzard skin will be applied and then sound deadening.
Lizard skin under the kilmat! Well done sir. you completed the idea i've been rolling around in my head.
Can I ask how much lizard skin you used and how much mat did you order?
I used 2 gallons of sound deadening and 2 gallons of ceramic heat. I was able to do 2 coats of the sound deadening and only one coat of the ceramic heat. It will be fine since there is lizard skin under the body also. I used 2 packs of the 36sq ft packs. Has no extra. Still planning on doing the doors.
