Build Another FJ68 Build
Member Build Threads
Working on steering lines and mounting reservoir
Ac evaporator core is pretty dirty. Have a new denso unit. Heater core looks pretty good.
Anyone have suggestions where to get the foam for around the heater core and all the ducts
Slow progress, but it takes time to chase all the unwanted wires. About 95% done cutting down the factory wiring harness. Then floor will be prepped and lizzard skin will be applied and then sound deadening.
Lizard skin under the kilmat! Well done sir. you completed the idea i've been rolling around in my head.
Can I ask how much lizard skin you used and how much mat did you order?
I used 2 gallons of sound deadening and 2 gallons of ceramic heat. I was able to do 2 coats of the sound deadening and only one coat of the ceramic heat. It will be fine since there is lizard skin under the body also. I used 2 packs of the 36sq ft packs. Has no extra. Still planning on doing the doors.
