another cracked dash repair (1 Viewer)
Raleigh, NC
I have wanted to redo mine. BUT ... I can't figure out how to get the dang thing out. Can you give a me quick run down of how to get it out?
Thanks
Durango Co
Hey man that looks awesome. Corners and lines look real nice. Still gonna holler at ya soon so maybe we can get together for that rotor replace. Take it easy.
Lubbock Tx
Next I covered it with glass cloth...not mat.
then I used mat along back because after ceck fit I saw a big gap
then I layed up 2 layers of mat on a sheet of window pane that was waxed so I would have flat pieces to fix the ends that had broke over like pig ears...lol...mounted them with a mixture of chopped mat and resin
Lubbock Tx
Then came puttin the cover on with contact cement and heat gun wacthing for air bubbles along the part that raises up over control panel. After I had it covered I found I couldn't fill the holes that hold the vents so I got some pvc 2in" elbows and cut and painted black to fill
Lubbock Tx
Sorry about how bad the post went, better at working on "Tommy" then doing posts, hopefully I'll do better on next one. Going to use same covering and the new carpet and cloth I'm going to redo the door panels. Till then I hope this helps explain how I did it so far
TemboTusk
Supporting Vendor
Anaheim, CA
Nice Job EW! A lot of work. The dash looks better than original.
When you get a chance, post up some pictures of the dash installed.
StL
How does the new cover match the door panels?
Man that does look good. I picked up another dash not knowing the results could come out so nice.
WW
Lubbock Tx
It doesn't match ..but when I get through with the dash and carpet I'm going to get cloth to redo my seats and at that point I will have all I need to redo my door panels..vinyl, cloth and carpet, then every thing will match and will be good for another 27 years ..lol..I hope
Elbert
AL, USA
yeah how about writing up how to remove the dang thing.
taking the dask pad out is the easy part. remove two screws, one one each side of the dash pad at the far edge left and right. Remove screws around cluster, remove screws around ac control panel, remove screws and remove gove box door and glove box, then remove the 3 or 4 screws that hold the dash pad along the back side near the windsheild, you'll need flashlight to see teh scerws. disconect a/c ducts... pad should come out then.
Go slow, don't force anything, remember that old plastic is very easy to break.
Users Who Are Viewing This Thread (Users: 0, Guests: 1)
