rkymtnflyfisher
Trout Bum
- Thread starter
- #341
aluminum
Blasphemy!
aluminum
Blasphemy!
Now, if your going to buy into the purist propaganda, you can send me the 4plus rear swing-out....Just say'en..
something to keep the beer cooler in!!!!!
Beep when you drive past Arlington rd. On 77north.Indeed sir, indeed.
(Semi-Hijack alert) Did some scouting on the Cheat River this afternoon. Things are looking pretty promising...Pick a Sunday (arrival Sat night) and come on down!! We'll test your cooler and roll cast. Headed to Lake Erie on the 17th of JUL to do some Walleye fishing...
Crawl, walk, run.
Cut some parts out, got prepped to weld new patch in on one side tonight.
@Chungas Revenge here is a shot of the bed support. It may be a candidate for replacement. View attachment 1221226
View attachment 1221227 View attachment 1221228
Got a little work done this weekend, after being KO like Rousey a couple weeks ago with the flu, I have finally gotten back to normal. I have done some cutting, grinding, and welding, got the rear sill welded in place. Bolted the tub back to the frame while I start on the rest of the body work. Dropped some coin on some gear lube for the tranny and t-case, still need to get the front and rear diff filled back up.
Just read your post from start to finish. I am inspired. Keep up the good work and pretty soon you'll have a mean rig!
Can you put a jack under a length of 2x4 and raise the body enough to bring it back together?
More of the Porter should help either way. You're moving along nicely.
