TCEd
In general are there any cons related to swapping in an aluminum tub ? Thanks, ed
Should use stainless hardware to reduce electrolysis.
I was told by the owner of aqualu-Todd to use loctite.So the rule is: stainless bolts with plastic washers and rubber feet under the steel hinge pieces? Should I use teflon thread tape on the threads of the stainless bolts?
That's interesting. Based on that chart, plain old steel bolts would work best with the aluminum body. Zinc seems worse than stainless steel?
Have you noticed any corrosion at all anywhere?I think, Stainless does well compared to regular steel or zinc hardware.
Anything to reduce contact area of the dissimilar metals helps reduce this.
Paint even helps. plastic washers under standard washers can be made quickly out of milk jugs. And I grease all bolts.
I did my Aqualu in 2005.
Has seen lots of rain, but stored under shed. Holding up well, even grounds of turn signals still work, but I coated them with silicone under washers.
