Aluminum tub seat mounting question (1 Viewer)
Buxton, ME
I am working on dry fitting everything in my tub. I mounted the seat brackets in the holes that were predrilled from Aqualu. The pitch between the mounts is 500mm (19 9/16"), but the pitch between the mounting holes on the seats is 515mm (20 3/16"). Has anyone else run into this issue? I'm not sure how to make up the 5/8" offset I am seeing in the mounting holes.
Aren't there left and right seat mounts? Are you putting the stock seats back in? There are a lot of seats out there that are more comfortable. I guess they will make it look stock.
I plan on changing out the seats at some point, but for now, the fastest way to get it back on the road is to use what I have
Something you may over look is where your steering wheel is after mounting the seats. You want the steering wheel centre of how you sit. If not then physical handicaps may occur. You could possibly weld a plate to the bottom of the sear with a hole to feed the bolt into the tub seat connection.
