No Austin dealers had the venza cap in stock today, so I went ahead with the oil change anyway. One broken tab later, I vow to order the venza cap to have on hand for the next oil change. Couple questions:
Torque settings? Venza cap and the filter drain cap.
This ones for Brian... on page one of this post, you show how to replace the tube and mention about watching out for the spring and disc. So we have a nice venza cap from Toyota, and nice drain valves from Fumoto. Would it be possible to leave off the compression valve pieces and fit an adapter to couple the venza filter cap to the Fumoto valve? Maybe even drilling and tapping the stock filter drain cap? Or adapter could just compress the stock filter drain valve spring. What do you think? I dont have the machining facilities to try it myself.
I have used that drain tool many times. To be fair, I’ve never used it with the oring. But the leakage happens initially so not sure the Oring would change it much.
I think it is hdpeit is not a norman plastic it is a very tough material - aluminium is not good - aluminium over time will weld to the metal and you will not be able to take it off.
I never do thatHeads up. First oil change in my new to me 2014. The dealer severely over tightened the bottom plug on the OEM filter housing. There was no way it was coming off without the filter housing. When I loosened the filter housing I just hand twisted it until oil started to leak out...right into my catch pan. 15 minutes later I just hand turned it until it came loose and dumped the remaining oil and filter element into the pan. The filter housing easily cleaned up with a rag.
I do not see any reason to remove the bottom plug. FWIW I do not see a reason NOT to repeat this procedure next time. Instead of using the 3/8” extension, I’ll just use the filter housing tool attached to a ratchet.
True that thanks mate.There is an o-ring in there that will eventually need replacement.
I have it. That is what sheered all the tabs off. It will not grip it now.They make a filter wrench specifically suited to the toyota cap. It should work even with snapped off "ears". A strap wrench, or piece of old fan belt with some vice grips might work too.
