I could use a little help troubleshooting my alternator. 1988, 3FE. I noticed that the voltage is not coming up like normal when running. Checked with a voltmeter at the battery terminals, and sure enough the voltage stays around 12 V even when running, and when I rev it up a bit. Fusible links have be redone recently so I think that's probably not the issue, but I'll check on them as well.
Also noticed that the little "battery" light on the instrument panel does not light up when key is in the "on" position. Nor does it come on when the engine is started.
Engine starts and runs fine. checked "charge" and "engine" fuses and they check out OK too.
Checked FSM, and figured I'd start with this -
OK, so "terminal B" is the threaded lug in the upper right in this picture (that should have a boot on it?) ?
Just trying to get this right before I fry something.
Thanks,
marc
Thanks,
marc
