If you want some extra amps for charging the second and third battery as well as the camper check these out, they are expensive but with 210/320 amps max output and idle amps of 120/170 they sure pack a punch.
http://www.m2kinc.com/pdf/45-brochure.pdf
wow!![]()
Good stuff hey!
How many output amps do you need?
... The FSM tells you to drain the coolant and move the hose going into the bottom of the radiator - I found this not necessary. It also suggests to remove the pulley from the power steering pump - also not necessary.
There was a lot more room to work under there than the FSM states. I had plenty of wiggle room to remove it. Entire job took 1 hour. Now I have bright lights on my dash, no more failing bearings and volts are back up to 14 - it was running approximately 13 and you could hear and feel the bearings failing.
I did not remove any hoses but I did push on them quite a bit. That is a tight work area. The alternator was touching on everything as it slide out.
Props to Utahfj62 and uzj100, y'all should be OB/GYNs...
Either way it worked for me.Smart shopper price with discount was about $220. I figured the original lasted 180K, and very few get reported on here as having failed, so I went with the Toyota unit, which is just a reman'd Denso.How much is the direct replacement alternator from the dealer?
I too am at 177,000 miles and I may just go ahead and swap mine out before it leaves me stranded somewhere.
