All 4 calipers locking up any ideas? (6 Viewers)
I am going to take a look at the cap and see if that cpuld be the issue before spending $1300 on a master cylinder and brake booster. I was watching videos online so just bench bleed the master, remove the 4 bolts and few houses for the brake booster install the master and brake booster then bleed the brake lines like normal?
If there is a write up could someone provide a link please.
MC and booster failures are apparently rare in the 200. I couldn’t easily find a Mud write up on replacement. There is a lot of great brake info in the beginning of this thread, so that may help with a bleeding.
Just ordered a master cylinder brake booster from bell lexus they had there 15% off, so saved $200 was only $1100 should be here wensday. I will do a write up on how to replace the master brake booster.
So update I tried bench bleeding it, spoke to bell lexus was told you have to use tech stream to bleed the master cylinder. Can I just pump the brakes and bleed using the calipers bleed screws.
The FSM does say you need to use tech stream. You can get a mini VCI cable and a copy of the software for $50 off ebay
I do have a scantool arriving tomorrow that does have the ability to bleed abs systems, I hope that will be able to take care of the issue. If not I will go online and get tech stream as you suggested. Thank you for your help.
Only time I saw something like this was someone bled the brakes with, as it turns out, diesel fuel that was in a brake fluid can …. Swelled up all the seals and locked up the brakes. Dumb stuff happens.
I totally agree mistakes happen but, I only use unopened bottles of brake fluid when doing brake stuff. I was told that it collects moisture once open, so any bottles thats over a couple months old is s***. Dk if its true but its something I always follow same as never using never-sieze on wheel studs, or spark plugs.
This was also doing it before I even touched the master cylinder/brake booster, unfortunately.
Just looked at my friends all data page, it says brakes can be bleed like normal and you only need to use techstream if there is air in the abs system. This is OE factory repair information.
