All 4 calipers locking up any ideas? (5 Viewers)
I am going to take a look at the cap and see if that cpuld be the issue before spending $1300 on a master cylinder and brake booster. I was watching videos online so just bench bleed the master, remove the 4 bolts and few houses for the brake booster install the master and brake booster then bleed the brake lines like normal?
If there is a write up could someone provide a link please.
MC and booster failures are apparently rare in the 200. I couldn’t easily find a Mud write up on replacement. There is a lot of great brake info in the beginning of this thread, so that may help with a bleeding.
Just ordered a master cylinder brake booster from bell lexus they had there 15% off, so saved $200 was only $1100 should be here wensday. I will do a write up on how to replace the master brake booster.
So update I tried bench bleeding it, spoke to bell lexus was told you have to use tech stream to bleed the master cylinder. Can I just pump the brakes and bleed using the calipers bleed screws.
The FSM does say you need to use tech stream. You can get a mini VCI cable and a copy of the software for $50 off ebay
I do have a scantool arriving tomorrow that does have the ability to bleed abs systems, I hope that will be able to take care of the issue. If not I will go online and get tech stream as you suggested. Thank you for your help.
Only time I saw something like this was someone bled the brakes with, as it turns out, diesel fuel that was in a brake fluid can …. Swelled up all the seals and locked up the brakes. Dumb stuff happens.
I totally agree mistakes happen but, I only use unopened bottles of brake fluid when doing brake stuff. I was told that it collects moisture once open, so any bottles thats over a couple months old is s***. Dk if its true but its something I always follow same as never using never-sieze on wheel studs, or spark plugs.
This was also doing it before I even touched the master cylinder/brake booster, unfortunately.
