Hi all - new to lx570 ownership
Virginia
Hey everyone,
Just got a single owner 2014 lx570 with 58k miles. Thing is a tank compared to all my previous vehicles and the engine is a beast I've only had the pleasure of driving when i was a valet in college.
Before signing up for a screen name, all my google queries consistently returned results from this forum and all the illustrious poasters who regularly comment here :)
As far as i can tell, highest priority seems to be watch out for radiator leaks. I have also been fascinated by all the info on globe accumulator replacement. Any advice on when to change those out?
The TPMS sensor went off two weeks after i bought it. All tires, including spare which i checked are full up. Reset button doesn't seem to be working. Vehicle came with some Hankook Dynapro HP2 285/50R20 tires. Decent amount of tread left altho i believe they are from 2023. Possible valve stem or sensor issue?
Anyway, stoked and privileged to get a hold of one of these machines. Looking forward to learning from you all and contributing where i can.
All the best,
Wstclx
Welcome! That’s quite a find……really low miles. It’s certainly possible a tpms sensor has a dead battery at 11 years. You can have that checked out at tire shop like discount tire.
I set aside $2000 for repairs/baselining 18 months ago when I got my 2014 - I've spent roughly $1500 of that doing globes, radiator, water pump, idler, thermostat, etc.
Looking back, I think the globes are probably the most time-related item on the list - yours are now 11 years old and might possibly have lost enough pressurized gas to justify replacement. The hard parts seem to be more a combination of time & mileage - and you are low mileage - so maybe monitor and wait.
There is some evidence to suggest that the coolant is also time sensitive. It's a cheap and easy replacement (use the Toyota 50/50 mix).
Go ahead and replace other fluids, just because. Plenty of baselining threads around for specifics.
Enjoy the ride!
Welcome. A great find with the low miles. A good test with the globes is if u can tell difference between sport vs comfort. If you can not then change the globes and flush fluid.
There is a lot of information and great members who will help you in this forum.
Thanks! Yeah was a garaged grocery getter. That's good to know...have friends with Toyotas that have been riding around for years with that indicator but seems annoying to me.
Enjoy the ride!
Hi Willie G, thanks for the warm welcome and great info. Super amateur wrench but i think i can tackle several of these items myself. The radiator spooks me a bit. Maybe i can work up to that. Cheers!
Thanks 32. That actually makes a lot of sense. I'm going to try that tomorrow. Lotta wisdom to be gleaned and generous people in here that's for sure!
Big difference here. Lot of curvy roads where im at so sport feels great. I will proceed with other baseline items and revisit the globes and fluid flush later. Thanks!
I believe the factory recommended service interval for changing AHC fluid is 60k miles. I'd look into have the fluid changed w/o replacing the globes soon.
Congrats on the find.. should serve you well for a long time.
I agree with those saying globes should be considered.. though they don’t necessarily need changed yet. Even if they haven’t seen as much of the pressure fluctuations that come with driving another 50-100k miles, ultimately a significant portion of the weight of the vehicle has been sitting on the compressed gas behind the rubber diaphragms in those globes for 11 years. There just has to be some level of degradation.
Maybe see if you can find a much later model low-mileage LX to take a ride in. Other than the larger wheels on the 16+ variants your system is basically the exact same. If there’s a significant ride quality difference in yours for the worse, globes are almost certainly the explanation.
Hey guys, knocked out a decent chunk of the baseline items but there's one thing that's not only annoying but a potential safety item that needs urgent attention: namely a break pedal that seems to slightly stick in the up/extended position upon start up and also after driving straight on the interstate for awhile.
I'll go to tap the brakes lightly and it's just stuck and I'll need to tap it again with more force. Brakes fine after that. Pedal seems somewhat inconsistent too like from slightly squishy to nice and firm. Got new akebono pads and rotors on it due to squishy pedal. Also makes what i would describe as a hissing/squeak when i press the brakes.
My vehicle also mimics the noise in the video in this thread with ignition on but engine off:
Any thoughts on what could be happening here?
Was the brake fluid flushed?
OEM parts are usually more reliable.
if you get a scan tool, you can let the....abs module? pump the brake fluid for you. I came prepared to have to use a pressure bleeder, etc but ended up going the OBDII route as I wanted fresh fluid in everything associated with the brakes.
Decided to look into this today...seems like most guys are comp sci majors with convoluted methods but finally found a guy on YouTube who made the techstream look doable
